IrisYuki
Is this worth its price? I heard the mic is really bad
I love the headset, but their dogged instance on mic side tone is one of the most annoying features on the headset. You can only get around 44-52% volume level on the mic without hearing your own voice. If I had a choice of flashing the headset with no side tone, I'd do it in a heart beat. It's their worst feature in my opinion and is not like that in most other headsets. Other than that, average mic.Is this worth its price? I heard the mic is really bad
I got mine for $300, and I think it's definitely worth it at that price. I haven't had a need to turn the mic up super-loud, especially since most voice apps have built-in boosts if needed. It sounds like Crutchfield has a 60-day return window, if you're not satisfied.Is this worth its price? I heard the mic is really bad
and none of you answered his question and gave your feelings on the actual mic quality.I got mine for $300, and I think it's definitely worth it at that price. I haven't had a need to turn the mic up super-loud, especially since most voice apps have built-in boosts if needed. It sounds like Crutchfield has a 60-day return window, if you're not satisfied.
Ah, sorry about that. I usually game with a couple specific friends, and I haven't actually asked them how the mic sounds, but they haven't had any issues hearing me, or being unclear. I'm not sure if it picks up extra sounds (keyboard clicks, people talking in the background, etc). I haven't tried using it for personal recording, but when I first got it, I turned on the voice playback to make sure it worked.and none of you answered his question and gave your feelings on the actual mic quality.
I got it to work found a working usb 3 port.Anyone got a tips on updating firmware? I fear I waited for to long. Sat on 1.3 downloaded the latest software and run it in admin mode. It starts the update to latest firmware but soon get firmware failed and I need to do a recover?
Tried various usb ports it detect the mobius on all but can´t update the firmware. have the mic muted and the headphones lying flat.
@Audeze Why does the Orbit S still have a battery? I can think of a few reasons, just curious as it again is a failure point on a headset which now doesn't have bluetooth. So why? I'm also still waiting to hear back from my previous post about firmware versions being different than the mobius and what's the correct version. As no where is it listed on a webpage that I can find.
I agree i suspect it's for the waveNX and 3d effects to have extremely low latency plus the amount of power required for the 1w internal maybe needs that extra unf.My (uneducated and uninformed) guess is for 3D effects (and maybe extra power for the drivers) when using the aux connection.
Yes. This is correct. Otherwise there is no way to power the electronics when using 3.5 mm. For version numbers, please email support@audeze.com and it is easier to keep track of it using the ticketing system.My (uneducated and uninformed) guess is for 3D effects (and maybe extra power for the drivers) when using the aux connection.
Stay updated on Audeze at their sponsor profile on Head-Fi.
