@Audeze Wanted to get some help on some stuff if you don't mind!
1. The mic volume seems extremely low. Right now under microphone properties, the level is set to 100. Under custom, "loudness" is unchecked, not sure what its for tbh. The only time the mic is at a decent level is if I max the mic out (which I prefer not to do as I don't really like sidetone) and if I talk very close to the mic. Problem with speaking so close though it picks up my breathing as well as the "pops." Currently the "Audeze" logo is facing outwards with the microphone logo facing inwards towards my mouth.
2. I have a tendency to put my computer to sleep when not in use rather than shutting it down. The mobius is connected 24/7 via usb on my monitor. I never manually shut down the mobius as I thought there is a automatic shut off. Everytime I wake my computer to use the headphones, the left side of the headphones is already warm to touch even though the computer was asleep. Do you advise that I actually manually turn off the comp or manually turn off the headphones?
3. Every time I fully shut down the Mobius and then turn them on, it seems to forget the settings and just defaults to "3D 8CH" even though the last mode I had used was Hi-Res.
1. Microphone seems to be correctly positioned. What application are you using for voice ? Is there any loudness correction in the app (eg - Skype or Discord).
2. Headphone warm - this means the headphone was charging. If you using it with your PC, it might be required to keep it plugged in all the time. The headphones should turn off if no connection is valid. With USB being connected to the monitor, Mobius probably thinks there is a valid connection. Turn off the Mobius and turn it on when you need it. It is probably easier than shutting down the PC.
3. We expected most people will use it in 3D mode and Hi-Res was added as a afterthought on the design. 2Ch was added just for PS4 compatibility. The default settings for USB was 7.1 + Manual 3D and BT was 2 Ch with Auto-3D.
As you can see, Mobius is a very different product and we are finding people use it many new ways we did not expect. For example there are people using it with Apple TV (AAC) and Nvidia Shield (LDAC). One of our users is a movie composer who is using it just to send his 5.1 mixes to the team. We are getting great feedback about the product. We will see if it would be possible to add some functionality either through firmware or software to make it easier for the users.
Stay updated on Audeze at their sponsor profile on Head-Fi.
