Regarding AUX INPUT - Analog Connection:
To know what (headphones) amplifier or line output level would be necessary or suited to drive Mobius Aux Input I have measured it's parameters.
WARNING: anything with a significantly higher output voltage is said to be capable of destroying Mobius!
Where this destructive limit is, only Audeze can answer, and (@KMann @Audeze ) I think they should give figures here.
Explanation: Mobius Aux Input uses an ADC (Analog to Digital Converter) with a fixed maximum input, which does not change when you turn Mobius volume control.
If you go beyond the ADC's limits Mobius will distort, no matter what the volume control on Mobius is set to.
The maximum undistorted level the Aux Input can handle is: 1.6 Veff.
The Aux Input's impedance is: 4250 Ohms, independent of frequency within the audio range.
The sensitivity of Mobius thru the Aux Input, 3D off, DefaultEQ, on Bruel&Kjaer 4153 coupler: 108dB SPL @ 1Volt, 1kHz.
This means, anything to drive the Aux does NOT need a lot of current, but about 1 volt of output voltage (not to be confused with the "hard to drive" discussion for high impedance dynamic headphones).
An iPhone, e.g, can do that.
Most desktop CD players line outs have 2V, so they are suited to drive the Mobius Aux Input, the 2dB overvoltage is reduced enough by the player's output resistance on most models.
Mobius is significantly louder (ca. 3dB) then a Sennheiser HD800, so anything that can drive the HD800 to sufficient level can easily drive Mobius.
BTW: the frequency responses are almost identical between USB and Aux, except for a low frequency roll off with a lower corner frequency of 22 Hz on the Aux, and a tiny deviation of 0.5dB in the left cup caused by different acoustic properties when the plugs are in or not.
That’s a bloody lot of detail
