bertchai
- Jul 18, 2008
While I am waiting for my pre-order of LCD2 ( about 3 months by now ), I heard that the quality of the latest badge is not as good as before. Anyone has any experience to share?
Well, the hand band height adjuster on LCD2, I noted that there are some made of aluminum and some made of plastic. What's on your?
Did you received an "Audeze" branded cable or Canare cable?
I notice through pictures on web that the wooden frame colour also varies a lot. The first badge is in a rose red wood colour and later ones in sort of walnut colour.
Pigwave, can you post the main LCD2 thread please?
My friend also received his LCD2 with PLASTIC height adjuster and they have taken away the metal/aluminum one (which looks a lot more high class and quality). Is this some kind of cost reduction or quality degrade.......
Here it is,
http://www.head-fi.org/forum/thread/453116/audeze-lcd-2-orthos/10800#post_7394084
You can use the tool " search this thread " to find out the informations you need.
About the plastic issue, I heard that AUDEZE can replace it with aluminum ones without charges, you may e-mail them to confirm
p.s. 3 months waiting time seems weird, you should ask Audeze for that or check your mail box, normally you should have received your order page
