greenkiwi
And the new BT audio is cool, it opens a separate 802.11 band to transfer the audio losslessly. (Don't know if it increases the range or not.)
Bluetooth v3.0 + HS[edit] Version 3.0 + HS of the Bluetooth Core Specification[39] was adopted by the Bluetooth SIG on 21 April 2009. Bluetooth 3.0+HS provides theoretical data transfer speeds of up to 24 Mbit/s, though not over the Bluetooth link itself. Instead, the Bluetooth link is used for negotiation and establishment, and the high data rate traffic is carried over a collocated 802.11 link.
The main new feature is AMP (Alternative MAC/PHY), the addition of 802.11 as a high speed transport. The High-Speed part of the specification is not mandatory, and hence only devices sporting the "+HS" will actually support the Bluetooth over 802.11 high-speed data transfer. A Bluetooth 3.0 device without the "+HS" suffix will not support High Speed, and needs to only support a feature introduced in Core Specification Version 3.0[42] or earlier Core Specification Addendum 1.[43]
http://en.wikipedia.org/wiki/Bluetooth#Bluetooth_v3.0_.2B_HS
