michnix
- Mar 7, 2009
If you had a favourite tune or CD to show off the LCD-X, which would that be?
I think you will probably get a better answer if you indicate the types of music you normally listen to in order to narrow things down a bit, because this type of question can normally elicit answers which are all over the place musically, and understandably so... If you typically enjoy EDM, and someone mentions titles in classical or jazz music, I suspect you might not find them to be too helpful...If you had a favourite tune or CD to show off the LCD-X, which would that be?
Oh, I usually listen to Rock, EDM, Jazz, Heavy Metal, Pop, Funk, Soul, you name it... and even some Classical music now and then A good recording of a live concert is heaven.
My rig is a Metrum Hex DAC, Audio-GD Master 9, LCD-X.
I just received both amp and LCX-X a couple of days ago after being out of Head-Fi for some years, owning Beyer T1 and a Violectric V100 for a while previously.
My question has different reasons: I want to find more good music of course and I’m still trying to come to terms with the sound of the LCD-X.
While enjoying the fastness and detail, especially in the bass region, I’m still surprised how little «direct» (in want of better words) those ‘phones sound. I would not go so far as to call them veiled as I’m hearing plenty of detail all across the frequency band but I expected less «distance» to the music. Everything sounds slightly recessed. First impression would be «muffled» until you listen more closely and noticing the amount of detail the LCD-X produce. Lacking experience with planar ‘phones I wonder if this is typical with this kind of headphones. Maybe it’s just some missing presence in the treble region that I am not used to, I don’t quite know... I find myself listening to louder volumes as I expected as I don’t find them quite satisfying at lower levels (yet?).
Yes that is just the signature of the X. Laid back treble and airy/spacious sound. You may prefer the Focal Clear for a similar price if you want less distance to the music as you put it, those are very present on treble and more forward sounding. Also better suited for lower volumes.
Maybe give it a bit of time and breakin. I did all my listening with Grado 325i HPs before getting the X. If you're interested, they also improve with better cables. In truth, I bought my Xs blindly, interested in trying the planar technology just to see what the story was. For the first day, I thought I'd made a big mistake, though it's hard to audition in this online economy. I'd suggest giving it a chance. They're now my main choice for listening. Mine are paired with the Hugo2, but I've driven them with my QP1R, just fine.Oh, I usually listen to Rock, EDM, Jazz, Heavy Metal, Pop, Funk, Soul, you name it... and even some Classical music now and then A good recording of a live concert is heaven.
Particularly the airy/spacious sound part is completely false. Trust me, you don't need to punish your ears with Focal, and there is something about that sound that actually seems too fast and less musical. It's possible that you'd prefer a Focal headphone, but the LCD-X having a signature incompatible with the music you listen to is plain wrong. You just need to do a few things, start with a Sonarworks trial, and I can almost bet you'll get this headphone to where you want it. It has innately good bass, which is one characteristic that might be less susceptible to EQ, DACs, and amps.
