Feynman
- Mar 5, 2011
Yes, for example here
No, the X is not exactly easy to drive. Also check the above link and other posts here. There is no issue with "not enough power" or whatsoever, it is about the X's mid-range if the amp doesn't match well. So you might need to play around a little before you really unleash it's full potential. But isn't that the fun part of it anyway?
Surely you are right in so far, that Feynman should first try the amps he already owns (if any). Maybe he is lucky and doesn't have to invest more...
I'll probably go for a Schiit Vali first since it's cheap, I can always use it for other headphones when I decide I wan't something new. I'm using a Bottlehead Crack w/ Sennheiser HD650 at the moment so unfortunaly I have to get a new amp as well.
The Woo Audio WA7 looks really tempting since it sports a DAC as well, and the price isn't up the roof as some of the other amps mentioned here
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
