Sound Eq
- Nov 9, 2013
using mx4 with hugo2 and ifi ican pro in tube mode is really amazing
So with that being said i am removing my mx4 from the for sale forum, next to me is my hifiman 1000se that i got today which is amazing as well, but right now the mx4 is the one that is giving me this wow effect
Literally i can not say enough how amazingly the mx4 sounds now
Since you mention the hifiman He-1000se, may I ask how it compares with the MX4, and which of the two you would retain if you had to let one of them go? I have also been considering upgrading my He-1000 to the SE, but I am not sure whether the difference in sq would be worth the considerable investment in $$$, especially since I still enjoy the He-1000 (with v2 pads and a Norne Audio Silvergarde S Clear cable) quite a lot. Your impressions would be appreciated.
He he told you so, they are great on Elear also. The MX4’s really sing now!hi, lcd mx4 with stock pads were not for me at all. with dekoni pads the mx4 is amazing like literally amazing,when I say amazing I mean in regards to how they transformed with the pads to turn into a really great sounding headphone. Which gave me the wow factor due to the change in sound after adding the dekoni pads
As for He1000se you know that the He1000 series are simply amazing headphones, they are very tough to beat, its still early to know the he1000 se by listening to them for few hours, so I have test it thoroughly with all music and genres to come to a final conclusion, so within a week I will be able to answer this better .
I can tell you this the hifiman 1000 se sounds way way better than hifiman 1000 V1 which I auditioned but not owned, but I owned the V2 only
but i can tell you this the mx4 with dekoni pads sound better than lcd4z with stock pads
Has anyone tried these with the Schiit Ragnarok? I've got a Lyr 2 right now and have really liked the Schiit products I've tried. An Amp or DAC is the next thing that needs upgrading in my system, if my pursuit continues.
I feel like a great amp is probably more important than a great DAC, and I already have 4 (albeit only up to lower-mid level) DACs. The Pro-ject Pre-box S2 is my main DAC because I use Tidal, so MQA compatibility is desired, but my Mojo also gets a good amount of use.
The Ragnarok is catching my eye at the moment as the next natural big step up upgrade. Given how people say it handles/improves IEMs with their low impedance, I imagine it might similarly bump up the MX-4's. Or would the community here say that, given how easy the MX-4's are to drive, it may be better to put that money elsewhere (like a DAC in this case)?
You may already be aware, but just in case, the release of Ragnarok 2 is imminent, so you may want to hold off on purchasing it for now. As far as how it sounds with the MX4, I haven't heard the combo, so unfortunately I can't say![]()
Not to rush you unduly or anything, but if anything in your impressions has changed on this MX4 vs HEKSE comparo front, since the last go-round, I wouldn't mind hearing about it at all. After several months of resistance that eventually proved to be futile, I caved and sent my He-K for the upgrade, and I am waiting for my HeKSE to arrive this week--actually tomorrow, if everything goes well... As you probably remember, I have owned the MX4 before (albeit, about just one month), and I'm also familiar with the house sounds of both the Audeze LCD-4 series and the He-K series, and that is why this particular comparison resonates with me on several levels.
You almost never are able to remove the old double sided tape they use to stick them on and so you would need to replace that with new tape but they only send you one set of tape with new pads so you will need to make due with something else. It's a terrible design to be honest.
