Great write-up, junmoe. Thanks.
Any suggestions for an aftermarket cable with a 4.4mm balanced connector for my Sony wm1a?
Hi everyone,
That's all for my first impressions.
All I can say is that I clearly advise anyone to try them if you have the opportunity.
I fully agree with your opinion, I'm enjoying them since a couple of weeks and they are astonishing. I'm driving them balanced from an SP1000 and I can't stop getting stunned at how this portable setup sounds. Totally different from what one is used to for an IEM, it just doesn't sound like one.
Personally I started using them with the locks and haven't even tried the hooks, I simply can't stand the idea of having to detach the hooks each time I want to store them in Audeze's plastic support (such a detail would have deserved more attention, Audeze). Not such an hassle with the locks. I must admit I struggled to keep them in place at the begin, until I actually took my time and read the manual, LOL. Once I figured out the correct way, they work very good for me. Actually, this is the first IEM I don't have issues with.
Does this use a standard 2 pin connection?
Some of my initial impressions:
@davehutch You were right. Not only surprised but blown away by the quality, depth and impact of the bass. A few posters mentioned the clean, punch, and taut bass - and yes, it is all that - but just wow, the i4 definitely have the means to rattle your brains if you have tracks demanding it. This whole time I thought my shure se846 were excellent in the bass section, especially in the iem sphere. se846 is up there. Well, it got left behind in the dust.. it's not even close. The bass depth and impact is much much stronger in the i4. I dont usually listen to hardcore techno in my leisure time, I go to Berlin for that.. I just dont see how bass heads could want more out of headphones unless they're prepared for bleeding into the mids. I'm new to EQ, but I totally buy the 900hz to 5hz flat bass response claim... and I'm curious to see how it'd take EQ. I don't have my LCD2 w me but from the feeling of auditory experience from the se846 to LCD2 wasnt nearly this drastic in the bass area. I remember wanting the LCD-X after hearing my friend's cans back in Paris but not anymore. I'm very happy w the i4's bass response.
Well, I use it directly from my iPod touch 6th gen using NePlayer app (with a bit of EQ-ing), and it sounds amazing. I tried with the Mojo, couldn't hear any significant improvement, in fact the Mojo makes it a bit warmer and losing a bit of sparkle therefore I decided to drive it directly from my lowly iPod touch. So I guess the Sony has more or less enough juice to make the them shine.
Wow, it's good enough just out of your iPod touch that you don't hear any significant improvement with the Mojo? I've been ambivalent about getting them because I prefer to be able to drive my earphones straight out of my iPhone with satisfactory results and not have to add an external amp and from all the posts in this thread I thought you'd need at minimum the Mojo (which I have) to do justice to the LCD i4. I currently have a iSine 20 and they're just amazing and such a joy to listen to with the Cipher cable setup, but if the i4 straight out of an iPhone sounds even better than that, I might just have to...
I'm confused, how did you connect the lcdi4 to an iPod touch? Does Audeze provide a lightning cable? Does the iPod touch have a headphone jack? Did you use that?
It is definitely good enough for i4. One note though, I'm not using the stock Music app, instead I'm using NePlayer app which brings significant sound improvement (and you can EQ) plus you can turn up the gain if you think it isn't loud enough.
Compared to my iPhone 7, the iPod touch 6th gen has deeper and more powerful bass impact and yet still retains the clarity and sparkle so it's a really good match for i4.
I see. Does that player itself bring sound improvement without using any EQ if compared to the stock Music app? I use the stock Music app with 320kbps files and I'm quite accustomed to its UI, so I'm a little averse to having to switch to another music app. Does NePlayer preserve playlists and my settings etc. from iTunes/Music app (so e.g. if I sync music across, it'll automatically show up on NeMusic like how it would with the stock Music app).
If you run the i4 out of your iPod touch using the stock Music app, is the sound quality a huge step down that it's very noticeable?
I use an iPhone 6S Plus so thankfully it still has a 3.5mm jack...and I think it's really quite good enough for me. I don't know if the iPod touch 6th gen has an even better DAC/amp than my iPhone though; if it does then my mileage would vary with the i4. Nevertheless, my shop ordered an i4 and it should be arriving sometime next week so I'll be able to check it out. They're actually offering me an incredible price for it (lower than retail after currency conversion!) but the offer is only going to last until the end of this month...maybe I shouldn't have gotten the iSines.
iPod touch 6th gen does have 3.5mm output, so no need for lightning cable. You can use the lightning to 3.5mm dongle that Apple provided for iPhone 7 if you'd like, but it will slightly decrease the bass impact although it brings out cleaner sound with more resolution.
