Loving it off my iPhone, the i4's. Such realism off a little cipher cable and a phone...
Audeze LCD i4 TOTL In-Ear Monitor Discussion
- Thread starter Emerald Core
jlbrach
- Jun 4, 2005
yes the i4 is really good..kind of like an open backed IEM
- Mar 12, 2009
Need Help here!
First time using the LCD-I4+Cipher cable on my iphone. I already downloaded the Audeze HQ app, but what EQ should I put there? I thought there should be a preset option, but I can't find it.....
I used to use the preset EQ from ROON on my desktop, but I can not find the preset EQ settings on the Audeze HQ app in my iphone......
Need Help here!
The preset is already there in the Cipher Cable!
Only make changes in there if you want to modify it.
Really? How does the cipher cable know what IEM I plugged in? I thought I have to set the EQ to the Cipher cable manually...The preset is already there in the Cipher Cable!
It has it's own little amp and dsp built in. So, it is designed to work with the i4 (if you have the i4 version.)Really? How does the cipher cable know what IEM I plugged in? I thought I have to set the EQ to the Cipher cable manually...
The Reveal plugin is suppose to be the same tuning or similar.
All Day Breakfast
No. Eminent is correct. This cypher cable only works for the i3 and i4 and has the eq+ burned inReally? How does the cipher cable know what IEM I plugged in? I thought I have to set the EQ to the Cipher cable manually...
So I don't need to do any eq settings? It will automatically know what IEM I plugged in?No. Eminent is correct. This cypher cable only works for the i3 and i4 and has the eq+ burned in
I brought the cipher cable from ebay, it is the v2 version. So it will automatically detect what IEM I plug into?It has it's own little amp and dsp built in. So, it is designed to work with the i4 (if you have the i4 version.)
All Day Breakfast
Just checking, is it the correct cipher cable for i4? There’s a different cipher for isine 10/20. If you have the correct cipher cable it doesn’t automatically detect different IEMs. It only works with i4 (and i3). You can’t use it with any other IEM.I brought the cipher cable from ebay, it is the v2 version. So it will automatically detect what IEM I plug into?
EagleWings
It can’t auto detect the IEM. It has a fixed built-in EQ and it is upon the user to make sure we are using the correct cipher cable for the i4. V2 is the correct cipher cable for the i4. You don’t have to use the EQ in the Audeze phone app. You can use it to fine tune it further.I brought the cipher cable from ebay, it is the v2 version. So it will automatically detect what IEM I plug into?
- Mar 12, 2009
Any suggestions for 4.4 balanced cable for i4? Ideally under $1k.
ozz007
- Mar 2, 2012
Using silver dragon from moon audio. Good cable im happy with it.Any suggestions for 4.4 balanced cable for i4? Ideally under $1k.
