So many things were said about the cipher cable, also by me. But what does it REALLY change?
Lo and behold, measurements of cipher cable as compared to a normal analogue connection.
Made on miniDSP EARS, so it may not be 100% accurate, but should give us a hint.
Notes:
- Definitely more meaty bass (+7 dB) as compared to the "bass light neutral" version without DSP!
Now we have a proper fun "V sound".
Before we had a portable bright "baby Stax SR-009"! (*)
- Also the "hole" at 3-5 kHz has been "repaired", maybe too much. Now we have a +10 dB spike at 2,5 kHz.
- Both versions give us enough higher highs to attract some bats! Mostly +15 dB at 12+ kHz, so it doesn't hurt very much, rather gives some aetheric air. I dunno if it's healthy for your hearing, though...
- I've also tried this cable with my CIEMs (Lime Ears Aether) and could not stand the bass, as it was too much for them
* Proof of SR009 thesis:
Looking quite similar, don't they?
Let's also see how does the other cipher cable work: the one provided with EL8 titanium!
What the heck? Not much happened here. Maybe 2.5 dB more lower lows, a little less bright mids, especially from 2 to 3 kHz, also -2.5 dB.
This is the cable I would re-use (after changing the connectors) as a neutral connection to my iPhone. May work much better with Lime Ears Aether than the other one
Remember there may be more changes in THD and other things, I'm only measuring the quantity of sound here.
I hope you guys foung that amusing! Cheers
