Livnmuskoka
For somebody that found the LCD4's too bright, my ears hurt just looking at this graph. Especially at the fatiguing 3khz where my ears are most sensitive.Really!?!?
Here we go again...For somebody that found the LCD4's too bright, my ears hurt just looking at this graph. Especially at the fatiguing 3khz where my ears are most sensitive.
There is nothing wrong with talking about the measurementsHere we go again...
It sounds like you’ll need to demo, eq or look at a headphone without that spike.For somebody that found the LCD4's too bright, my ears hurt just looking at this graph. Especially at the fatiguing 3khz where my ears are most sensitive.
If your ears aren't as sensitive and they work for you, then great. But I wish more headphone and speaker companies would offer models for people with good/sensitive hearing. I do have EQ with my RME dac, but don't feel I should have to use much EQ with $6k headphones. Maybe I'm just picky.Here we go again...
If you have an issue talk about it don’t insult or ridicule or complain
It says measurements in the title of the thread
The measurement rig that was used to measure influences the measurement graph. For example, this is the measurement for Stealth using the GRAS 45C. Harman also uses GRAS as their reference system.For somebody that found the LCD4's too bright, my ears hurt just looking at this graph. Especially at the fatiguing 3khz where my ears are most sensitive.
Maybe lcd-5 aren’t for you, that’s okay too.If your ears aren't as sensitive and they work for you, then great. But I wish more headphone and speaker companies would offer models for people with good/sensitive hearing. I do have EQ with my RME dac, but don't feel I should have to use much EQ with $6k headphones. Maybe I'm just picky.
Exactly - it’s that simpleIt sounds like you’ll need to demo, eq or look at a headphone without that spike.
Maybe you should also mention the measurement graph differences between the GRAS rigs, which is the mostly used Harman reference rig and the 5128 rig that is being used by HeadFi. The measurements in this thread give wrong impressions to people that use a different reference in mind.It is quite risky to look at a measurement and form a opinion even when said measurement has other headphone measurements superimposed unless the other headphone uses the same earpads. How the earpads couple with the measurement rig affects the measurement's considerably and this is not a nice linear relation , A/B comparisons based on such should be taken with a huge lump of salt especially beyond 2khz.
As a part of the tuning process we also verify music played via a pair of speakers EQd to flat to 10khz and slightly tapering from 10kHz on up and we do this mostly in a near field setup. Once the Speakers and the headphone is level matched, to our ears, LCD-5 portrays the mids just as the recording calls for, not more, not less. We have also confirmed the same with few mastering engineers for whom it is important that their recordings is reproduced as is and not colored by preferences. I can say the same for treble balance too.
Does that mean LCD-5 is absolutely perfect, I will be lying if I say yes, no headphone is perfect. There is always some room for improvement, but I am just surprised by some EQ suggestions I have seen being posted so far. When it comes to EQ, just because our headphones can take more, does not mean one needs to go crazy with it, sometimes less is more
Monitoring this thread to waiting for your comparison with Diana Phi! LCD-5, by far, is a headphone that pick my curiosity through the roof.i tried it fast to check the treble. a friend was passing by and made me do a few minutes test. i made an order yesterday even because i want one now. i might compare both once i have it in a month +100 hours burn in too. ordered a DH cable too.
cant comment yet, my friend not in the country even haha xD i wish i borrowed it earlier. give me a month and few weeks and i shall compare it here later on ^^
I had the same thought at first but I have been told on this thread that if this graph were normalized, the peak wouldn't be there.For somebody that found the LCD4's too bright, my ears hurt just looking at this graph. Especially at the fatiguing 3khz where my ears are most sensitive.
Ok thanks. Have to hear them for myself someday then.I had the same thought at first but I have been told on this thread that if this graph were normalized, the peak wouldn't be there.
