Audeze LCD-4
- Thread starter Matias
- Tags
- audeze-lcd-4
Fegefeuer
- Mar 17, 2011
well, most of you guys will use your custom LCD-4 cables anyway.
Swisstoni
Looks like there is still felt between the ear peace and the ear cups !!!I like the wood color and the Black Grills.
The old headband looked better imo
The cable looks alarmingly thin and fragile.
ThanatosVI
Definitely.well, most of you guys will use your custom LCD-4 cables anyway.
Glad that they use Mini XLR
Fegefeuer
- Mar 17, 2011
No better connector than that.
Axel
- Oct 17, 2003
Well, it certainly looks like an Audeze LCD, no major exterior design changes. I just hope it doesn't weight ~700gr like its predecessor...
BTW, the cables looks similar (if not identical) to those on my LCD-4z.
Barone Birra
It looks like 420 gr... (hard to believe, tho)
MachineGunz
This was just published on Ecoustics:
https://www.ecoustics.com/products/audeze-lcd-5-headphones/
Price is 4500$
Price is 4500$
Features:
- New Parallel Uniforce™ diaphragms and Fluxor™ Magnets provide powerful sound, unparalleled sonic detail, and incredible accuracy without increasing the impedance
- New internally sloped earpads that help to reduce unwanted resonances and interior reflections
- Newly designed Fazors that are optimized to reduce diffractions
- The LCD-5 cable is specially tuned with directional OCC high-purity copper strands that provide a low capacitance and low resistance path to maintain unsurpassed clarity and precision.
- The LCD-5’s fully re-designed magnesium frame provides rigidity and ultra-light weight, while the acetate rings offer just the right touch of richness
Specifications
Style | Over-ear, open-back |
Transducer type | Planar Magnetic |
Magnetic structure | Fluxor magnet array |
Phase management | Fazor |
Magnet type | Neodymium N50 |
Diaphragm type | Nano-Scale Parallel Uniforce |
Transducer size | 90 mm |
Maximum power handling | 5W RMS |
Maximum SPL | >130dB |
Frequency response | 5Hz – 50kHz |
THD | <0.1% @ 100dB |
Impedance | 14 ohms |
Sensitivity | 90 dB/1mW (at Drum Reference Point) |
Minimum power requirement | >100mW |
Recommended power level | >250mW |
Weight | 420g |
arftech
- Dec 3, 2010
Specifications
Style Over-ear, open-back Transducer type Planar Magnetic Magnetic structure Fluxor magnet array Phase management Fazor Magnet type Neodymium N50 Diaphragm type Nano-Scale Parallel Uniforce Transducer size 90 mm Maximum power handling 5W RMS Maximum SPL >130dB Frequency response 5Hz – 50kHz THD <0.1% @ 100dB Impedance 14 ohms Sensitivity 90 dB/1mW (at Drum Reference Point) Minimum power requirement >100mW Recommended power level >250mW Weight 420g
arftech
- Dec 3, 2010
$4500?
ThanatosVI
14 Ohm impedance O.oThis was just published on Ecoustics:
Price is 4500$
Features:
Specifications
90db/mW
That one loves current. Pretty happy with my speaker amp now
4500$ will likely translate into 5000€ like with the CRBN (which is weird since the LCD-4 is also 5000€)
Deceneu808
5K LCD-4 ? Why ?14 Ohm impedance O.o
90db/mW
ThanatosVI
Europe, greed and profit margins.5K LCD-4 ? Why ?
Exactly the same reason why Solitaire P costs over 6000$ in the US while it's only 4800€ over here.
I do like the LCD-5 Design. The headband takes some getting used to (I really liked the old one) the pads seem interestingly different.
Deceneu808
It's 3853 EUR in my country, also Europe. and CRBN is going for 4564 EUR. I'm guessing the LCD-5 will sell for the same.Europe, greed and profit margins.
Also I'd like to give those pads a try on my LCD-X
Total: 9 (members: 0, guests: 9)
