Audeze LCD-4
Nov 27, 2015 at 4:32 PM Post #1,801 of 11,988
  It may be psychoacoustics, no? Better aligned treble has more perception, therefore bass has less, phones seem to be brighter?
That's probably what it is.  The Fazor revisions are less dark and it causes people to think it has less (sub) bass.
Nov 27, 2015 at 4:43 PM Post #1,803 of 11,988
Dude, you said you didn't understand how anyone could pick the 3f over the X, my reply was explaining the reason the X didn't appear there (in other words, I wasn't rating the X at all). And of course it's about preference, the very comment you responded to was a statement of my preference. Sorry I didn't rate your X, but no need to jump down my throat.
Try not to misquote me if thats ok. I said in terms of bass. I understand many reasons why someone would pick the 3 over the x - but bass is not one - it seems obviously so much better i was confused as to why you would pick the 3 for that specific thing - or anyone for that matter. I wouldn't say the hd650 has better imaging over the hd800 but I would pick the 650 as a headphone over the hd800 - but similar to this I could never say the imaging is better. That's my point.
Thanks.
Nov 27, 2015 at 5:01 PM Post #1,804 of 11,988
I couldn't believe my ears with the LCD-4s...I thought the LCD-X's bass was already outstanding, but it appears that there was room for improvement with the LCD-4.
Wow, that's very exciting...I'm addicted to the bass on the X...deep, impactful, and most importantly, CLEAN. If the 4 betters them, then wow...that's very impressive indeed
Nov 27, 2015 at 5:03 PM Post #1,805 of 11,988
  There seems to be confusion on what a fazor does and what it doesn't do. So here is some more explanation on Fazors and how they work. Fazors are for upper mid and high Frequencies management and don’t have anything to do with the bass extension. The Bass extension on these headphones are pretty much the same if they are Fazored or Non-Fazored. Here is a simulation from comsol.
Non Fazor
Fazor
Fazors do four things
a. They remove the diffraction around the magnets when sound goes through them. Diffraction effects are related to wavelength and the size of the obstacle. With our Fazors Low frequencies are not affected by this at all.
b.  Sound Stage & Imaging - There are two things related to this - How big the sound stage is and how accurate it is. We do a lot of tests and recordings ourselves to determine where instruments are placed and how accurate the sound stage and imaging are. Here is an example of us doing a recording early this year. In these tests, we accurately mark the position of the performer and compare them to reproduced sound stage. We listen to the live performances and also to the reproduced sound.
The fazors make the audio wavefronts more coherent. This in turn makes the sound stage more accurate. We use both Audeze microphones and other microphones for these tests.
c.  Efficiency. The fazors increase acoustic impedance in the space between the ear and the driver. This gets us a bit more efficiency.
d. Phase coherency. This is why we named it fazor.
Thank you for your explanations.
How do you explain the difference in the bass extension with the fazer?
It is audible and it is confirmed by measurement:
http://www.innerfidelity.com/images/AudezeLCD2Rev2.pdf
http://www.innerfidelity.com/images/AudezeLCD2sn5423021Fazer.pdf
Thank you for your reply.
Cheers
Nov 27, 2015 at 5:30 PM Post #1,806 of 11,988
Cheers
The previous explanations were: new testing methods, new testing equipment (I think), driver wear/break-in, testing anomalies. It left me wanting.
Nov 27, 2015 at 5:50 PM Post #1,808 of 11,988
Except the measurement I gave wasn't done by Audeze and my ears was the same during the comparison...
:wink: I hear ya. The Fazor really shouldn't change anything below 350Hz, so it's very confusing.
Nov 27, 2015 at 5:59 PM Post #1,809 of 11,988
  I had both 3F and HEK at the same time for several weeks.  After finding the right amp to drive the HEK I ended up selling the 3F( I owned the 3F as my reference for several years).   The HEK scaled so much better than the 3F did and the improvements were quite noticeable.  May still look in to getting a LCD4 but I am in no hurry (which means I'm still hot on the HEK ).  I don't miss the 3F at all.
What amp did you end up getting for your HEK?  I enjoy mine out of WA7/tp but it feels a bit underpowered for HEK.
Nov 27, 2015 at 6:37 PM Post #1,810 of 11,988
Well I had the Burson Conductor Virtuoso which in theory should have been enough power with 4 watts.  But it also felt like it was underpowered.  The deep bass and the slam just wasn't quite there yet.  I tried a few other smaller amps but I eventually switched to the Violectric V281 & V850 combo and I am very happy.  It has plenty of power on tap...  I am even thinking about trying out a pair of Hifiman HE6 which is extremely difficult to drive.  Here is a photo of my setup:
By the way- Violectric-USA ( http://violectric-usa.com ) has a Black Friday special going on.  25% off all equipment and any purchase over $500 gets a free pair of interconnects.
Its a $200 pair of interconnect and it sounds really good:
Here is a small review I wrote on the interconnect should you be interested:
http://www.head-fi.org/t/786838/introducing-violectric-by-lake-people-cables#post_12062189
Nov 28, 2015 at 1:31 AM Post #1,811 of 11,988
Well I definitely believe Audeze changed the drivers when they switched to fazors.
The measurement differences between pre and post fazor are so consistent. If not, someone would have just taken the fazor off to get back the classic bass. Unfortunately I don't believe removing the fazor does that
Nov 28, 2015 at 4:12 AM Post #1,812 of 11,988
Yes Audeze also changed the driver (to 110 Ohms) for the LCD 3 at the same time. I have had both the fazor (2014) and the no fazor LCD 3 (2013) at the same time and the older one had a bit more subbass. The LCD 3F has on the other hand a bit better clarity, speed and a wider more open soundstage. The treble has also a bit more energy and the whole sound is a tad less forgiving.
Nov 29, 2015 at 9:42 AM Post #1,813 of 11,988
http://headphone.guru/the-new-big-kid-on-the-block-the-awesome-audeze-lcd-4/
Great review, for those of with 3 and Xs it's time to start saving!
Nov 29, 2015 at 10:23 AM Post #1,814 of 11,988
Well, Peter certainly makes the LCD-4 sound very enjoyable.
