Only if you NEED to go balanced, Audeze already give you a cable that work well
You are right, 2.5mm balanced cable for my Astell & Kern
Q Audio Cables are still making cables, I’ve bought cables from them and love them.
Same here.People keep quoting this, but I'm telling you from direct first-hand experience that there's a difference between "driven to listenable levels" and "driven to 100% of its dynamic potential". They can absolutely be driven and enjoyed with a lower powered source, but there absolutely will be dynamic potential left on the table.
As I sit and test them between a mobile source, the Asgard 2, and the A100, their dynamic ability scales with the power available. There's a reason Audeze specs the LCD-2C as requiring >100mw but they recommend 1-4w in the manual.
+1 I really wanted one of these headband's but I ended up getting the carbon fiber one for my LCD-XC'sWhen will they make these headbands available on the accessories store???
Has anyone used the LCD-2C with the Cavalli CTH ? If so does it have enough power, what does the combo sound like ? Thanks
Well I finally got one and I'm currently running through a Mojo, really like it so far.
Take my impressions with a grain of salt since I only just got them and I don't have trained ears or higher end equipment to power them at the moment. If I compare the LCD2C to the iSine 20 with the cipher cable the 20/Cipher has more detail but is also more fatiguing. The LCD2c is a really relaxing listen and allows me to listen to music that was just way too bright on the 20/cipher combo. Yeah they're somewhat veiled but just enough that I can still hear nice treble without my sensitivity to treble making me want to pull off my headphones. If I had to pick a headphone closest in sound to the LCD2C it's the HD650, if someone was looking for a planar equivalent this is it IMO and I'm sure it will scale with better gear just like the 650 does.
If I had one complaint it would be that the headband creates a hot spot on top of my head but that may just be a sign I'm in need of a haircut
Edit: I actually kinda think it sounds better out of the KANN than the mojo, now to either find a 2.5mm cable or a 4pin to 2.5mm trrs converter so I can try the balanced headphone out
I started listening to my 2c out of the box with several inexpensive and expensive ($75-$400) . I decided after sever days of listening to try the stock cable.Has anybody changed the stock cable that came with there Classics im gonna be using Magni 3 for my Classics when they come i like the look of there cable but think it might not be long enough what have people changed to im in the UK so really the question is to people in the uk so i can go on site and order a cable if i want to change
