MrGreen
- Oct 9, 2009
I'm 21 with good hearing for my age. Regardless, hearing damage typically results in hyperacousis after a particular period of time, which results in people being sensitive to the range in which they have damage (which is usually in the 2-8k range, most often around 6khz - which is right where the HD800 has a spike) - which typically leads people to AVOID sounds in this register (meaning they would probably seek out darker headphones). Hyperacousis is terrible - for example, you find things like the fridge, or someone chewing to be too loud. I personally have ideopathic hyperacousis (well, they call it ideopathic because it is a ppears acquired rather than related to hearing loss, although I believe it due to surgery I had when I was a child), although thankfully mine is quite minor (it's mostly ~70+ dB that I find very irritating). I've always taken issue with the "hearing damage" argument (which typically comes from the fans of dark headphones) because it's based on an incorrect logic; hearing damage affects every sound in a particular range (well, the most common types of sound). It's going to change the balance of the "real thing", just as it's going to change the perceived balance of headphones. Theoretically, your preferences will not change - or rather, should revert to normal unless your preferences were the result of an extended period with a particular sound signature (in which case I'd argue you'll probably stay with that headphone anyway). Anyone seeking "the real thing" won't be affected by hearing loss - beacuse your new hearing IS the real thing.
There's also a huge, unecessary stigma on this forum about getting old with a clear misunderstanding of what frequencies are important. Sure, harmonics are going to differentiate two notes played by the same flute player at the same volume from one another - if you are unable to hear them - which you usually can at most octaves - it's not going to sound "bad" by any stretch. The audibility of these differences is also completely questionable, given how "mute" a harmonic is relative to a fundamental unless it is being specifically targeted (through overtone series exercises, for example).
Just because someone has a preference that is different than yours does not mean particular members have inferior hearing. As an audiophile with a rather technical background here's a piece of gold for you: your ability to listen is more important than your ability to hear. A legally (and profoundly) deaf person who goes to a concert to hear the thud of bass probably has THE MOST FUN out of everyone at the concert - because they rarely get that sensation. Furthermore, that single person, even if they can only hear a kick drum, has every right to seek out the highest quality kick drum the like. Our more seasoned members, probably rank amongst the best listeners - because they've probably been in the game the longest, regardless of their hearing.
Being an audiophile isn't about having the highest quality hearing - or even the highest quality sound. It's about enjoying and appreciating the gift of sound.
