Lyssky
for how many hours should LCD2 closed backs be burned in you think?
And also do amps have burn in requirement?
I liked the Mojo but I didn't like the Mojo with all my headphones. The Mojo works well with older Audeze headphones. The LCD-2CB's are more neutral sounding and I think that's why you may feel its lacking some bass with the Mojo.@Left Channel thank you
@Slim1970 So how would you compare Centrance DACportable to Chord Mojo. I tried Chord Mojo with LCD 2 CB and it produced really smooth sound but lower bass compared to Oppo Ha2 but I really liked its smoothness, way better than Ha2.
So what would you say about the smoothness and warmness of DACportable compared to Mojo? I like bass but I may choose the clearness Mojo provides over the bass.
Also does the treble eq of DACportable cause brightness on LCD 2 CB when listening to metal music?
The DACPortable works with just about any headphone. It has that natural class A warmth. To my ears it's just as clean sounding as the Mojo with a bit more musicality. The bass boost works wonders with headphones and is especially beneficial with IEM's. The treble boost is also well implemented. It doesn't make anything sound harsh or overblow. It adds just the right amount of detail to the top end. I have both the bass and treble boost on when I'm listening to the LCD-2CB's and they sound great. Plenty of drive and dynamics with more bass impact and definition.
Also with what do you connect the DACportable to your iphone?
Yes, either my iPhone or iPad
I use the Apple lightning to USB3 camera adapter with a Apple 30W USB‑C Power Adapter and Apple USB‑C to lightning cable. I can charge and connect to any dac/amp with this setup. Links below:I meant with which cable? cck?
I has a question about diaphragms clicking Yeah, again. So, clicks from both drivers. Cans was bought couple months ago, and drivers clicks from start. Almost silent after night, but more after several minutes of listening. Audeze says it's normal for planars, air pressure, bla-bla-bla. But... Should i worry or forget and relax? Maybe other pads can fix pressure issue.
PS: Sorry for my English )
That is not normal. I have never heard clicks from a headphone unless they were caused by a problem upstream, like in the DAC, in which case I heard them in my speakers too.
I mean situation like this https://audeze.zendesk.com/hc/en-us...cking-static-sound-when-I-press-on-the-earcup
It's not electric clicks, it's mechanical effect.
