Thank you for the impressions.Total bullxxxx. There's a world of difference between V2 and BT. As mentioned in your link, the trebles are missing, basses too little pressure and simply too little juice in the whole! And just extremely annoying that the Audeze HQ app does not work. Otherwise you could use EQ to get things moving. But not like this.
The difference from V1 to V2 is very big. If I were you, I would have bought the V2 cable and done without BT. V2 is definitely much better than V1, more power, much better tuned to the iSine. Like I said, it doesn't need EQ. It sounds really great and you can get deafening volume or distortion! You don't get that at BT.
I got two of these stupid BT cables now. Yeah, I'll throw them away eventually. I don't need them. Always listen with a wire. I'm already fed up with the eternal charging, the mobile phone is enough and if you have to charge all the headphones as well, it gets really tedious. Also there so stupidly made, smallest rubber lid over the charging plug, which one hardly gets open.
No dear Audeze, the BT is a flop, unfortunately I cannot say otherwise! Please detain and rework!
Unfortunately, I'm quite hooked on wireless so I probably end up using it (and I have Andoird). I had little time a few hours ago to unbox it and the cable itself is pretty high quality compare to my other cables I got from Amazon (mostly Chinese/generic).
From memory, the build is a bit better than Shure's and lighter than RHA's. But, I HATE the damn micro USB....why???!!!
I will update back with a more detail impression, but for a quick 15 min listening, I have to agree with you how the treble isn't as pronounced. However, I can't say I hate it. It's a nice change compare to stock cipher V1. I do, however, feel like the bass is a bit more though, which I don't mind at all. I'd love to try the V2 given how much you praised that.
The i3 seems like a distant purchase for now. I've been seeing mixed reviews so it kinda put me off.
