udesign48
I assume you are using Cipher or some type of EQ?
I'm using Moon Audio iSine silver dragon cable. No EQ applied.
I'm not very impressed with Audeze house sound.
Thank you for your reply. It sound like maybe the Nickel and the iSine aren’t a good combo. I had thought maybe the power available with the nickel would suit the iSines. Have you tried using the nickel together with the zx2? I have both UAPP and neutron on the zx2 and find neutron to be the better of the two on ZX2. You may want to give it a try, if you haven’t already.
Hi,
You mentioned the third printed style. Which one are you actually using? Which link? I would like to take a look. TIA
Any changes in you eq? What are you currently using. I have still been using your eq, and also use the cipher cable with I devices.
This would be great. All the stuff I use (ES100 and Sony ZX300 mainly) is 10 band EQ. Someone posted a link several pages back to 10 band settings and they are the best I've tried to date with the iSine 20s.Was thinking of starting an Audeze EQ thread for people to share,, I have KManns and Brainiac for UAPP
Maybe you could sell them to a user using Eq or Cypher, trust me you will make a happy userI'm using Moon Audio iSine silver dragon cable. No EQ applied.
The LX / 10 / 20 pretty much require some EQ to sound their best, this is def not the Audeze house sound.I'm using Moon Audio iSine silver dragon cable. No EQ applied.
Not every headphone works for everyone. Since you already have viable options, sell your iSines and move on.How would you EQ them? Honestly, iSine 10 sounds very fake 3D. It tries to get that 'wide soundstage' which they advertise but in such a non-musical way.
It's true it sounds wide but it doesn't sound very legit.
I prefer sound of HD800, H650, SRH1840. Sony N3AP and Etymotic ER4SR are close to them.
Did your iSines come with a cipher cable? If you have an Apple device, you can use the cipher cable (and it's accompanying app) to eq the iSines to your personal sound preference. If you're on Android, you can use a music player app with a built-in eq (USB Audio Player Pro, Poweramp, Neutron, etc) to adjust the sound to your preferences.How would you EQ them? Honestly, iSine 10 sounds very fake 3D. It tries to get that 'wide soundstage' which they advertise but in such a non-musical way.
Unfortunately, it didn't. It came with standard 3.5mm audio cable and I bought Moon Audio silver dragon isine cable.
