Thank you donyoubhave a link for Aliexpress with the same cable
Audeze iSINE 10 & iSINE 20: Audeze releases two new IEM planar magnetic earphones
- Thread starter Madcat207
Is the same cable on Aliexpress or another?
stmiller
You can find one on Aliexpress. 2pin 0.78mm cable with a groove in between both pins. Then you simply pick any termination you want.. 3.5mm, 2.5mm, 4.4mmIs the same cable on Aliexpress or another?
Do i need 0.78mm or also 0.75?
I would buy this two:
https://m.de.aliexpress.com/item/32...aYV7&aff_short_key=eqbaYV7&aff_platform=msite
Do i need 0.78 or could i use 0.75 for the isine 20 too?
SoundSquare
0.78mm and make sure that the connector has the small groove on the frontal side in between the pins
Thank you for helping me out. I searched for some cables, could you say if its compatible:
https://m.de.aliexpress.com/item/32...VVzv&aff_short_key=jiMVVzv&aff_platform=msite
https://m.de.aliexpress.com/item/32816683195.html
https://m.de.aliexpress.com/item/32...h-0-75mm-0-78mm-MMCX-Pins-Interface-Verwenden
Would you one recommended? Or all the same?
SoundSquare
1 - no, it won't work, the connector is recessed, It won't hold/fit.
2 - yes, but you'll have to find a way to remove/cut the ear hooks (the rounded part of the cable after the connector that goes around your ears on regular IEMS, you don't need it for the iSine, the cable must be straight, hanging.)
3 - no, angled connectors are a bad idea for the iSines. You need straight ones.
4 - yes, same as 2, get ready to do some surgery to remove the ear hooks.
Thank you with your picture in know what you mean with grooved.
I think this is a great Deal without ear hooks
https://m.de.aliexpress.com/item/32...QVf&aff_short_key=VnYZvQVf&aff_platform=msite
or do you think Number 2 is a priced but better choice?
SoundSquare
The last one should be fine.
Thank you but is it 0.78mm?The last one should be fine.
SoundSquare
i can't be certain but it looks like yes. Where are you located actually ? maybe you can find some custom cables makers in your area ?
Im from Cologne (Koeln) Germany. I didnt think so. I was hoping there is a cable that recommended, i have good and bad expirrence with cooper Cables. Is there an adapter out that makes a Unbalanced Cable to an Balanced? Or still i need a Balanced Cable it self?
I dont think the 100$ Cable worth the extra money, so i could go with the 35$ Cable.
Not sure about cheap cables, I have bought two from Penon, one costed me like $15 and the other is a nice $50 CS819 cable. Both came with grooved connectors and no ear hook, but the connectors didn't hold tight enough in the sockets. Just a bit of pull would remove the connector from the socket.
Some people here seem to have no problem with the cables but my experience told me it would be a gamble.
My stock 3.5 cable was busted and the nearest one I could find in EU was from Switzerland and costs 69 CHF.
If i can buy it with Online Banking i would try it. I just need a good Balanced Cable
