Deckard916
Isn't Android a CF to develop for? I thought that's why they haven't done anything with USB C cable yet.
tried so many eq recs but nothing compares to how amazing isine20 sounds on ios using cypher cable
its a shame that this iem sounds its best just with cypher cable
yes you can get decent sound quality using eq on daps or android but its not comparable at all as using cypher cable
What really bothers me is that they could at least have made a USB version for Android since so many DAPs run Android and zero DAPs run iOs. They would sell a lot more cipher cables if that was the case. But given my hatred of all things apple, I can't even really try it to compare for myself....
I've heard both that it's better and that with a proper EQ and a decent DAC it really isn't any better. For 60 bucks itd be a no brainier for me to try, but I'm not buying a ridiculously overpriced old iPod or iphone just to do it.
Wait, isn't the thing about the lightning cable that it's an inline DAC with some control from an app? Even just an Android app with special EQ settings would be nice using the normal cable. Also, not to mention I'm using a balanced cable and the cipher eliminates that option....I gave up and returned my B-stock iSine20 (came with standard cable only). Spent hours searching for/applying eq settings, but never got to a point where I could just sit back and enjoy them. Between listening via phone, tablet, DAP, or PC I'd need eq settings for each. Interestingly enough, the iSine20's had good synergy with the Sony A45. Alas, the amount of effort needed to tease the right sound out of these was more time than I had or wanted to spend. Have to admit I was crestfallen as I was always fascinated with the thought of hearing and owning these. I have not heard the iSine20 via lightning cable.
As for an Android USB DAC, I think Android's lack of a standard (due to the multitude of manufacturers, devices and versions) make it a nonviable solution, especially compared to Apple's MFI certification. Certainly can't blame Audeze for not wanting to invest in such an overwhelming challenge, even though I wish there was an Android counterpart.
I'm happy with my b stock isine20 on my hiby r6. I thought the standard 10 band EQ settings were a good starting point. Honestly, I'm hesitant to believe that the cipher cable is some kind of voodoo, but would like to try it still given the mixed reactions.
Then you didn't have a decent DAP with decent EQ softwareme too time to buy an iphone, as i used my ipad
yes using isine20 on a dap or android with an amp/dac and eq was ok
but nothing like it sounds with cypher cable at all
i was really surprised as i did not expect this huge improvement
using isine20 with cipher cable and tidal or deezer is all one would need, now i can say that the isine does stand out from conventional iems
Because the cipher cable is just a simple DAC chip with some DSP settings in software nothing more, there is no magic in this cable
Sorry but this is bollocks
LG V20 + viper4android destroys cipher cable on all levels, I tried it myself
You can get a decent a 1000$ DAC but it means nothing for the isine 10/20 if the EQ software is not decent, because there is where the magic really is. it's all about decent DSP/EQ settings that isine needscompared with elecom dac, which uses ak4430et chip, cipher cable or elecom got better quality. not an i devices fan. so tempted to get an iPhone just for the sake of the cipher cable.
http://www2.elecom.co.jp/products/EHP-AHR192GD.html
Hi,
I’ll expose here my situation and hope you guys help me clarify it. At home I use a LCD-3 and Audio-gd NFB-11, which I really like, it’s almost my endgame.
But due to work necessities, I’ve been spending 30% of my time in hotel rooms in another country, usually 2 or 3 weeks in a row away from my LCD-3. That sucks.
So I need a portable setup to give me some pleasure, but I know nothing portable will achieve LCD-3 levels. And my budget is limited at the moment.
Right now I’m using Etymotic ER4XR and FiiO Q1 Mark II, and while the tonal balance is very good and details are acceptable, soundstage and image suffers, and they’re very important to me.
I was thinking about FLC8n and keep the Q1 Mark II.
But now I’ve considered the idea of the iSine 10 or 20, with a Cipher cable. Why not? It’s planar, it’s Audeze, no need for external amp, and I can EQ to my taste, although I don’t like EQ on full size headphones. I know fit is not good, but I’ll listen inside a hotel room, completely static in bed or in a chair, just like I do with the LCD-3.
Questions:
1 - iSine 10 or 20?
2 - Is the 20 worth twice the price?
3 - Does anyone know of any good deals in Europe?
4 - The 2 presets that can be saved inside the Cipher cable, work in any iOS, even without the Audeze app installed? It means the EQ is stored inside the cable and is independent of the app to work?
Thanks for the help!
Please define "not a great as cypher cable" what "HUGE" differences did you notice?totally understand your point, and I am as well not happy that this huge difference is only for ios users to enjoy, Wish if Audeze could address android owners.
using a dap or a phone with a dac/amp with isine can get you decent results, but not as great as cypher cable
Also which DAP did you try to use and what software?
I used my cowon plenue s, fiio x5iii , mojo, and ifi micro dsd black label all in different configurations, simply put cipher cable and ios bests them all
I could not nail eqing the mids at all, they sounded weird using it on a dap or android or an amp/dac
Equing mids is a hell of a task with regular iems let alone the isine20, and as much as i used to use eq but I noticed that eqing mids almost everytime ends up in failure. Anyhow the tuning with cipher cable was easy and turned it into a great sounding earphone with great mids that are full and rich and bass is controlled and tight and the highs are detailed but could be better, Tuning the isine20 with audeze app was very simple to achieve, all i did just bump the lows by 6 db and the highs by 2 db and left the mids almost untouched in the cipher cable app
is the isine20 better than my legend x of course not, but now with cipher cable its a different thing to enjoy
