Attn: Foobar2000 users (CROSSFEED plugin headsup)
Jul 12, 2009 at 1:40 AM Post #61 of 209
Originally Posted by taso89 /img/forum/go_quote.gif
I found that the way the Naive crossfeed plug-in adjusted for "human ear absorption" made the soundstage more fatiguing and unpleasant. I think Bauer is better explained and has some science behind it, at stock it sounds a little too mono but at the Cmoy preset it's very pleasant to listen to (and that's the point of crossfeed anyway).
Is it unpleasant to you because of the added brightness? It just happens to be a nice match for my current system which is why I don't mind the extra brightness. I tried Naive before and it bothered me too used with a different rig. Anyway, as far as just the crossfeed is concerned(not the tonality side effect), both plugins are actually pretty similar when sliders are adjusted to have the same amount of effect.
Jul 12, 2009 at 8:18 AM Post #62 of 209
yes, the default naive sounds very supportive to the brain...but I think I still prefer it w/ the 3 min. settings. too bad they keep crackling
I'll look for an alternative today, such as the 4Front : http://www.yohng.com/goodies/headphonesvst.zip
Jul 12, 2009 at 8:36 AM Post #63 of 209
tried the 4front a long time ago. maybe 2004/2005. It zuuuucked. Wonder how it is today if its been updated.
Thats weird that you hear crackling on the naive. I don't have that problem with mine.
Jul 12, 2009 at 8:40 AM Post #64 of 209
well, I'm quite crazy about the Ennio Morricone OST's....and they sound really mono w/ the stock naive settings.
I dunno why the damn thing crackles when I set them to the minimum....anyway, I will look into VST plugins. that's the pinnacle of audio plugins
PS: if I set the naive settings to one third, it seems to be a good in-between...I hope it won't crackle.
Jul 12, 2009 at 11:27 AM Post #74 of 209
the other plugin is really good for me. wow the extra bass is also a perfect match with the ad900s while the crossfeed is about the same as the naive. Love it so far!
Jul 12, 2009 at 11:31 AM Post #75 of 209
the second one is more transparent I think, ideally I want a crossfeed plugin that you can't ABX...I'm aiming at a subliminal DSP to keep my neurons happy. nothing more.
