I´m really sorry about this mess. I you want to return kann you have to do a factory reset either. If it is still version 1.20CM after the reset - give it a last try connecting it once again with your network. Do not change anything else. Only activate in Roon - do not change anything else. If it still drops Roon playback you should be able to return ist with full refunding due to European regulations if you have ordered via internet.
I have tested my Kann again. The only 4 Problems which are remaining for me:
1. Playing an Album from Tidal (integrated in Roon) via Roon playback let often skip the first one or two Songs. If I skip manually back to the first song it works. I can not fix this behavior. Albums from my local database are always played flawless. I have to live with - maybe a future update will fix this.
2. If I accidentally press one of the physical buttons the Roon playback skips to anywhere. I hope a future update will fix this also.
3. The main processor of the Kann is ..... not a monster when it comes to CPU and GPU power and maybe is also responsible for some of the flaws during streaming.
4. Aaaaand - please give me crossfeed for the A+K Player!!!!!!!!!
But still A+K is the only brand which offers Roon Ready functionality in a DAP. And the Kann is much more agreeable than the mobile Roon Endpoint I used before (Chord mojo with poly - which got extremely hot during playback and poly had a really bad stability of the wifi). And not to forget: It drives my Hifiman Arya
- perfectly- it is on the same level than my RME ADI2 DAC FS.
So I will keep mine.
