and DHCP-Server is the Fritz!boxI understand you are using roon ready on kann alpha. I have a small request in this regard. Can you give me some details about the architecture of your wan, lan network. What is connected to what, over the wire and wireless.
What equipment do you use, and last but not least, what are your wifi router software settings in detail, what frequencies, what channels, what strength, etc.?
Thank you very much.
I understand that in your case suddenly switching off sound playback in this function and visibility of kann alpha in core roon zones does not occur? That is correct.
I also use the Urban version.
Astell&Kern Launches KANN ALPHA Digital Audio Player
- Thread starter JasonNYC
- Tags
- astell&kern kann kann alpha
I sincerely thank you for your detailed description and your time. I will still be looking for weaknesses in my configuration including the core upgrade to windows10 which I have a license to. In fact I have never experienced any problems with it but at the time I did not have KA in my audio collection. I will share information once the operation is complete.and DHCP-Server is the Fritz!box
Problem solved!!! Thanks again for all the suggestions. They were helpful.I sincerely thank you for your detailed description and your time. I will still be looking for weaknesses in my configuration including the core upgrade to windows10 which I have a license to. In fact I have never experienced any problems with it but at the time I did not have KA in my audio collection. I will share information once the operation is complete.
I had to simplify the network map and remove the old router and switch - both TP-Link . These devices were affecting the Kann Alpha's roon ready behavior.
I purchased a new Asus RT-AX55 router, which became the Acces Point for the ISP modem.
I now have fast and stable lan (1gbit/s) and wlan (about 800/900 mbit/s) dual-band. Kann is using 2.4 ghz wifi. The connection is excellent.
So my suggestion for similar problems is to check and understand the network map and look at the network connections
Kann stays with me
klyaksa
HaProblem solved!!! Thanks again for all the suggestions. They were helpful.
Kann stays with me![]()
I must admit that the main problem was the network architecture. Now the Kann Alpha does not unexpectedly turn off playbackHa, so all the same the problem is not in the Alpha, but in the router. Everything worked out and works and there are no wifi drops?
But it invariably needs to be provided with a very good wifi signal. It is good to manually select the channel with the best parameters.
davidmthekidd
- Nov 14, 2015
Like many have said before, it all points towards weak Networking, I highly recommend Asus/Linksys.I must admit that the main problem was the network architecture. Now the Kann Alpha does not unexpectedly turn off playback
klyaksa
This is greatI must admit that the main problem was the network architecture. Now the Kann Alpha does not unexpectedly turn off playback
klyaksa
NeedtoBurn
I have discovered that the router and proximity to it has a big impact on whether my Kann Alpha buffers while playing music from the sideloaded Amazon HD app. I use an OTG adapter with my iPhone XS that is connected to the Kann Alpha in USB DAC mode whenever I encounter a situation where I am steaming with a weak WiFi signal. This workaround seems to solve the buffering problem with the WiFi signal.
Happy to hear!! Now you can enjoy the Kann and Roon together - which are really a dream team for mobile use in the house!!Problem solved!!! Thanks again for all the suggestions. They were helpful.
NeedtoBurn
Has anyone been able to measure the power output in mW for the Kann Alpha at any resistance? I searched this thread and found one estimate of 4,500mW @ 32 Ohms (post #1,001) and another estimate of 1W/1.4W @ 42 Ohms (post #1,004); I am assuming that these figures are for the balanced outputs in high gain. I am skeptical of the 4,500mW estimate based on comparisons with my headphones using my other source gear, and I believe it is closer to the 1,000mW estimate.
I am curious if anyone on here has equipment that can measure the true output in mW since A&K is one of the few manufacturers that lists the power specs only in VRMS under no load conditions.
klyaksa
This value is not constant. If you calculate, 12vrms is really 4.5W, but this is hard to believe even because the Alpha battery is less than 6A. I think no more than 2W in balance at high gain is the maximum, but what kind of output current will be interesting given that this is important for magniplanar headphones.
Tomm11
I doubt it's even 2 watts but that's going by nothing other than comparisons to desktop gear in which the output power has been measured. I'd love to see a standardized rating system for all DAP's from all manufacturers but that's never going to happen.
klyaksa
Naturally, they will not tell you about the real powers.I doubt it's even 2 watts but that's going by nothing other than comparisons to desktop gear in which the output power has been measured. I'd love to see a standardized rating system for all DAP's from all manufacturers but that's never going to happen.
Total: 7 (members: 0, guests: 7)
