Anyone else's volume wheel "stick" when rotating it with pressure that isn't perfectly perpendicular to the axis of rotation?
No issues here at all.
I don' know if the KANN does toslink via 3.5mm...the Line out 3.5mm that I can use to toslink which quality has? 32/384? Microusb has 32/384
Yes my question is if i can exclude or bypass internal amp, and which AK DAP can do it, thanks!
Excellent. I' m using the LO with my home audio systemWhat is the quality of analog line out?
The KANN line out is the analog output of the DAC bypassing the volume control and internal amp.
Yes. 24/192 as well as native dsd but as an analog waveform. Not digital. Digital is thru usb out only.but exactly? 24/192?
So using 3.5mm analog output i can bypass internal amp e volume control? good, now i'd want know what quality analog output has. Thanks again to everybody!!!
