SilverEars
- Sep 18, 2013
I do mean Mojo.
How do you clean your Cu?Hi all, I own an ak380cu, but I realise that overtime, the unit tarnishes a lot faster than when I first got it. Is there anyone else that is facing this issue? Or is there a way to slow down the tarnishing of the copper? Thank you!
I was told to use autosol metal polish.How do you clean your Cu?
It tarnishes really fast which is something I dont understand. May I know how old is your unit?The protective coating from A&K does not last very long, this is true. The internet tells me that Autosol also protects the metal, so I am surprised that you have to polish your Cu so often. I personally use Unipol, which commonly used for the protection of brass instruments. It is rather oily and protects copper from tarnishing for some time. It is enough to polish it every two months or so.
So do u have any suggestions on what is that layer of "protection" i can use after polishing so that it will maintain its shine? thanksThe thing you have to understand is that the "tarnish" is actually a layer of copper oxide. If you remove it without applying a protection afterwards, oxidation will occur again very fast, especially if you have wet hands, since water will speed up the process.
There are products that will turn the ugly greenish copper oxide into another oxide that is less colored and more resistant, to better isolate the fresh copper metal underneath from further oxidation. But it's less efficient with copper than it is with iron.
In other metals (titanium, aluminum...), the oxidized layer is not colored (just a slightly darker hue) and hard enough to protect the fresh metal underneath from further oxidation.
Which is why copper is initially such a poor choice for a chassis that is going to be handled primarily with dirty/greasy/wet hands.
So to clarify. u use metal polish on the cape cod polishing cloth?I no longer have the CU but when I did, I used:
https://www.amazon.com/gp/product/B0128B5JZ4/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
You apply the polish and use a microfiber cloth to buff clean. Washing the cloth in hot water and soap afterwards is all it takes to clean it. In CA climate that is low humidity and no pine trees, it stays polished for about 2 weeks (rose gold color) if you don't touch it much and it gradually fades for another 4 weeks to reach a copper color, but still shines. I never waited long enough to see how long it would take to reach tarnished look, but I would predict a couple months. The one really irritating thing is that the area around the power button can tarnish in a matter of days since your finger is touching it a lot and depends on much clean your hand is.
