bflat
Why does AK DAPs say "SD Card Safely Removed" when it's clearly being used? Maybe the it's a typo and should "Remove SD Card Safely"? Keep thinking it's rejecting my SD card every time I see the notification.
I know, me too. I always thought it was either because English is perhaps not the manufacturers first language and they had mistaken the context, or that activating that gadget will achieve what the message says. But was never sure.
Confused me too, but is just bad English, I think. Is A&K not a US company? I know they're made in Korea.
Maybe they could fix some of the confusing English in a firmware update.
They could really do with fixing the way the 380 turns off the amp if you leave it for 5mins - total pain putting the phones back on, pressing play and wondering why no sound - then having to turn the amp back on and then having to turn it back up to listening volume again. I know they say it's to protect our hearing but every amp I've ever had remains switched on and set at my chosen volume until I decide to change it - why not this one? I've not damaged my ears in 40yrs of amplification...
Using the CD Ripper now - it's very easy to use with the cradle (only the cradle's plugged in to the power) and auto-ripping's a doddle, although it is much slower than using a pc or laptop cd drive. Just remember to turn the wifi on for Gracenote.
I got my AK Red Wined and it now has deep, powerful, sonorous bass while retaining all its previous magical properties. AK need to take this on board when designing their next flagship. For me, however, the DAP war is over. For the time being..
Got the Dignis case in navy blue. I didn't notice the pics on the Dignis site, but there are some wear marks on the corners. Since both the pics and the case I received have nearly the same wear marks, I suppose this is by design.
The US email support confused me - easily done - thought they were US company but stand corrected!
I was using a Fostex HP-V1 with the HP-P1 before and the bass was just magnificent, so perhaps I was just used to more bass. Perhaps with IEMs that are easier to drive this isn't an issue but my Audezes have a very tight bass response so maybe with full-sized, harder to drive phones a little extra punch is required.
Question - now that I'm using the ripper (sounds a bit dodgy and violent..) I want to delete the music I put on using the Android file transfer app - am I best to use the app and just delete the files or can I quickly delete directly from the player itself?
Using the amp too.
I must say that I have never heard better sound than the from the RWAK380+Amp.
Brought tears of joy..
I can't see wear marks on mine. Could you link to the picture where you see this as I must be looking in the wrong place. I posted pictures of mine earlier in the thread. Do you see this on the pics I posted? Maybe I am blind
Using the amp too.
Using the amp too.
