STAXNBSAK380
- Oct 15, 2016
I also didn't notice any change in sound through my Jupiter, balanced.
@STAXNBSAK380
Are you using the docking station or HO?
I am not using a docking station.
@STAXNBSAK380
Hello etteoh thanxs for your post. For me the sound quality difference between firmware 1.32 and 1.40 is unfortunately and undoubtedly existent. The experience of your friend concerning SQ before and after the update would be very interesting. Compare the high frequencies and bass pressure and depth of the stage. I look forward to your report.
Sorry, I'm derailing the topic a little but does anyone here who can read Korean tell me / us what this "hidden" menu on the AK380 is:
Go to Settings > System Information and tap on "Model Number" repeatedly (5-7 taps). You get this menu, which looks to me like some diagnostic menu of a sort but it's all in Korean. I can't read Korean and definitely do not want to mess things up by hitting the buttons and see what they do. For all you know one of them could mean "Self Destruct"![]()
This existed for quite some time now actually. I asked @songmic for help a few years back and he helped me with it :-
AK240 Hidden Menu
설정: setting
블루투스: bluetooth
오디오: audio
터치: touch
번들 설치: install bundle
공장 초기화: set to factory default settings
설정 초기화: set to default settings
I think the AK380 menu is mostly the same.
Im coming back again on the SQ Issue with the 1.40 vers. I did a test and realized that AK Has setup the initial good SQ to Tidal application while the SQ in the native audio application lost its quality. I took a FLAC track Same characteristic with the one in tidal. When I listened to them, the sound in ak audio application was flat and too bright, while the quality was very good in tidal application.
Has anyone came across an issue where the 380 amp isn't working? The Balanced Out on the Amp works perfectly fine, but I am not getting sound through the SE. SE and Balanced out work on the AK380 fine without amp.
You're welcome. Coincidentally, I was just talking to my friend about the update. He did the update to 1.40 from 1.32 this morning and like me, he was not able to hear a difference in sound quality / characteristic post upgrade. He also did not hear any hiss. This was tested both with and without the AK amp module. His was done using a JH Layla whereas mine with the FitEar MH334, TG334 and my trusty ol' UE Triple.Fi 10.
He was originally very hesitant to do the update after I shared your findings with him but like me, he succumbed to TIDAL
This is not the first time I'm saying this and it won't be the last either (AK, listen up please) but it is exactly for reasons like this that I feel AK should provide older firmware available for users to go back to in case they don't like what the new firmware does to their DAPs. I have nothing against AK but we do have every right to choose what firmware we want to stay with. Not everybody wants TIDAL, not everybody has a Recorder and more importantly, there has not been one time where everybody likes the same firmware. I don't know what AK's reasoning is for not making previous firmware releases available for download but it's definitely something I'd like to understand.
Did somebody (AnakChan maybe?) have the chance to compare the sound of an AK380 DEMO unit (with 32 GB internal memory) with a regular AK380 unit?
I had the chance to compare an AK380 demo unit to my AK380 Copper, and the AK380 demo is SO MUCH WORSE soundwise, that I think the demo unit MUST also be inferior to a regular AK380 (duralium). The sound difference is just enormous, both with and without my copper amp. Both players are on the same firmware (1.31).
Any thoughts?
Thanks,
Bernie
Thanks to you etteoh and to your friend for sharing your experience concerning soundquality before and after 1.4 firmware update. I am a little bit confused that you didnot perceive the difference, as I undoubtedly do. I ll try to checkout with my local Astell & Kern distributor / supporter, whether he is able to bring me down to firmware 1.32. So I am able to check out, whether I deceived myself.
Your are right that A&K should offer older Firmware. I would appriciate a possibility in the preference pane to downgrade the firmware to older versions, in case the actual firmware upgrade version does not match the personal SQ taste. This would be an premium feature on this premium player and would enshure that upgrading is no oneway direction with the risk of disappointments afterwards.
Hi,
did anyone of you have the chance to listen to the Orilolus mk2 IEM´s out of the AK380? How do they pair? Thanks in advance!
I did but in my experience it wasn't "so much worse". I have a feeling firmwares were at play though 'cos back then it was demo had 1.18 and the AK380Cu had some1.2x firmware. I can't find my post now as it was some time back.
Your test was with the SR-007 - i.e. you were using an electrostat amp in between whilst with @ettoh's tests, it was earphones straight out of the AK380?
