Sound Eq
- Nov 9, 2013
hello everyone, if i want to connect the ak380 to another amp is it advised to set my ak380 to line out?
I am a huge fan of AQ Diamond myself, used them off my computer connected to HD and USB Dacs etc..they take over 1000 hours to really sound their best though which is a bummer.
Should add it completes the sonics of the Aurender Flow...
Hi mate....
My usual preference using another third party amp with the 380 would be to use the volume pot on the 380.
Maximum volume on the amp so you take out the resistors of the volume pot, and use it like a power amp rather than integrated.
WARNING:
Please be careful on volume, and always remember to start player and turn volume to ZERO, Don't want you to blow your ears which I have had happen to me before....
Three weeks to heal, no music and a $350 medical bill........
The original packaging came with 3 screen protectors, have you used them all?
I have a spare if you require. Let me know?
I only got 2 for the LCD screen, one was defective right out of the box, the other one was used on my old housing, the other screens are for the carbon fiber back ... so far I haven't gotten a scratch, and having no screen protector prevents dust from gathering around where the edges of the protector and the screen meets ....
I went with your recommendation for Quiet Winter Nights in 24/352.8 and the download took forever as the 'Download All' didn't work and I had to download all 15 tracks piecemeal lol, the album is well over 4GB, I'll move on to your other recommendations soon enough
thanks i always thought that it was the other way around, and thats why there is a line out
but good to know form someone experienced
i actually tried your advice now, i connected my ak380 to headstage arrow 5tx which has a great bass, so i set my ak380 to line out and i have this bass heavy song, and on my 64audio adel u12 i noticed there is clipping when i set the ak380 to line out, now after i followed ur advise above there is no clipping in the bass. thanks for the advise.
can u explain to me again why that is the preferred method in a bit more detail
Hi mate....
To go into more detail...
You are now using the 380 like a preamp for control of source which is on board....and the amplifier as a power amp where all resistance/resistors are taken out of the signal. Resistors are used to attenuate the volume. Hence, volume pots such as Alps tend to be expensive parts as they interfere less with sonics..
Of note AK players generally have a good clean line out be it to head phones or as true line out.
However, you notice clipping as many portable amps will have their inputs overloaded by a true 2.3 Vrms out which I believe the AK380 is ......
mmm.........AK USB cable failed? The supplied USB cable with my Chord TT also failed (to connect). That's why I use ALO Audio USB Green line. It works perfectly every time.
its just amazing how much difference is in power between when i connect my ak380 to a headstage arrow 5tx and stock ak380 amp, its a huge huge huge difference in bliss of joy listening to music when connecting the ak380 to another amp, especially when you consider how tiny the headstage arrow is compared to the bulky heavy ak380 amp, that in my opinion is simply so underpowered.
I know exactly what you mean about the amp. Just as a goof I connected my AK380 to the ALO Rx, and the sound was fantastic. I think I suggested earlier that AK hire Ken at ALO to design their next amp, and of course, Vinnie works with Ken. Can do much better than those two.
mmm.....yeah, I can also vouch for Crystal Cable interconnects and cables. They are tough, little buggers. No intermittent signal ever. No discolouration. And they are beautiful.
