- Aug 9, 2006
Kudos to you with respect to your article release regarding the AK380!
To briefly summarize your review, unloaded (No headphones attached) the AK 380 has the industry “lead-leading” audio metrics compared to other DAP’s. However, unless you have it plugged-in (loaded) with either the built-in amps with low impedance IEM or headphones, the “lead-leading” audio metrics fall apart to varying degrees. Is this correct?
Now that AK has released its external amp and assuming it is “very very very good”, then the AK 380 coupled with the new amp could potentially be the very best portable and transportable set-up one could hope for!
The AK 380 sounds fantastic with the Layla's and optically connected to the Cord Hugo sounds amazing with either the HE-1000 or the Senneiser HD-800’s headphones.
Is there a benefit “sound and/or audio metric wise” if I strictly used an amp vs. a DAC to connect the AK380 player too? If so why would I benefit from replacing my Cord Hugo with just an amp?
A few comments regarding your article:
Respectfully your friend in audio,
- “NL” is your abbreviation for “No Load” but why is it not reference in the unbalanced portion of your review. It is clearly referenced in the balanced section.
- I disagree with your comments regarding the “screen is “good quality”. Yes it’s clearly bigger (if that’s what you mean) but in my view AK has taken a “step-backwards” regarding the technology used. Although the AK240 display is over saturated with color I continue to dislike the bland lack of color regarding the new display.
- The volume button does have “good feel” but I clearly don’t like where the volume button is located. It is not practical especially when it is located in your jacket breast pocket or in your pants. It takes too much effort to reach the volume control to raise and lower the volume when you’re on the go. The location of the volume knob was better situated with the AK 240.
- The corners are edgy and I agree but they are NOT sharp as sharp indicates you could be cut and this is NOT the case. And don’t worry it not going to affect your….
-Speed
Thank you for the feedback. I appreciate it.
I missed this post among the fuss.
As to the amp, I'm not sure. Good integrated amps nearly always outperform outboard amps in terms of adhering to original signals. Obviously outboard amps can be much more powerful. I assume it will be more powerful, but unless it has access to the internal signal it shouldn't be able to keep up to the signal of the AK380. It may -- and depending on -- how/for what headphone it is built, be able to sustain current into difficult loads better than the AK380.
- NL: no load. I reference it in the review in both balanced and unbalanced and, at ohm image, show both balanced and unbalanced loaded and unloaded.
- the screen isn't as contrasty, which isn't quite as fun looking, but is a bit more colour neutral next to a calibrated monitor. (I'm an advertising product photographer by trade.)
- volume pot: it is more solid than the AK240. Its metal machining is better. I agree on placement. But that thing won't fit in a jacket pocket anyway. I reviewed it as a good-on-table-only device.
- If you press your hand, or catch the AK380 falling, it will definitely let blood. It is a bad design. But no, they won't cut like a knife. I used the 'cut' a bit figuratively.
Thank you again for your feedback. It was wonderful.
