variable114
- Dec 9, 2006
edited
Originally Posted by siddiquehanif /img/forum/go_quote.gif before i already tried asio v2.8 and v2.7 with foobar v9.5. i downloaded this from asio4all website (ASIO4ALL - Universal ASIO Driver) but it wont show up in foobar! |
Originally Posted by jterp7 /img/forum/go_quote.gif Also the second link you have for the asio plug in for winamp leads to a post about a sony DAP, i'm assuming this is a side effect from the downtime for head fi from the fall. |
Originally Posted by jterp7 /img/forum/go_quote.gif nevermind: it looks like asio is against more than 1 device enabled at once. |
Originally Posted by jterp7 /img/forum/go_quote.gif This may be slightly annoying as the plug in will need to be reenabled in both whenever I switch. The other alternative is to run everything through the pico...but is it good to constantly plug in and remove alternating between my "speakers" and the hd650s. |
Originally Posted by jterp7 /img/forum/go_quote.gif alright What..now my winamp using asio skips now and then..and it seems directly related to me doing other things, nothing intensive, even surfing the web seems to cause it to skip...foobar didn't do this..are there other settings i'm supposed to change? |
Originally Posted by jiiteepee /img/forum/go_quote.gif Hmm... those issues comes mostly from too low latency settings / priorities (have you set priority to background services) but, are you sure TBAAM WDM drivers are 'fully' KS compatible? You can check this by selecting Kernel Streaming output mode. jiitee |
Originally Posted by lromlin /img/forum/go_quote.gif Should it prio to background services or not? Ty |
Originally Posted by jiiteepee /img/forum/go_quote.gif Yes, background services. jiitee |
