Oct 11, 2022 at 5:47 AM Post #511 of 3,450
I assume you now have AAC codec support (I ask as I am on dev build so have had for a while)?
I only did the betas and recently came off when 22H2 got released. So, if it's not in 22H2, I haven't got it yet.
Oct 11, 2022 at 7:39 AM Post #512 of 3,450
AAC support in Windows 11 is live since first official release. I mean I upgraded to Win11 right when I was able to and it was there.
I just ordered Intel Wi-fi 6e AX210 + pcie to M.2 card since my MB have only one, already accupied M.2 slot. I will reuse pigtails from dead routerboard and it should work.
Oct 11, 2022 at 6:35 PM Post #513 of 3,450
Just watch the size as m2 card have tiny MHF4 size (not same as MINI-PCI, very easy to mash.
You would have been better buying that Gigabyte model or similar as it come all ready to plug into a PCI-E slot and plug in an internal USB 2.0 cable.
Oct 12, 2022 at 9:15 AM Post #516 of 3,450
Any USB device I have used on the Shield works, the last was the KB9P recently.
It got me aptX Adaptive 24/96 so same bitrate as built in LDAC confirmed via PowerAmp and by the Dongles LED colour and all other codecs SBC/AAC/aptX/aptX HD/LDAC (no aptX LL) via PowerAmp and the FiiO Neckbands LED colour.
Hello,
You seem quite knowledgeable in this area.
May i ask what the benefit is of USB Bluetooth dongle for Shield if using LDAC as Shield already has built in LDAC?
Oct 12, 2022 at 11:42 AM Post #517 of 3,450
May i ask why didn’t use the built in Ldac on Shield? Perhaps due to latency lip sync.
Oct 12, 2022 at 3:03 PM Post #518 of 3,450
I used the KB9P USB Dongle as a test and it was to get aptX Adaptive, I think you may have read that I also tested it with the FiiO BTA30 PRO which does LDAC but again it was only out of curiosity if it would work or not and the only real benefit would be aptX LL which the Shield does not support.
Oct 12, 2022 at 3:44 PM Post #519 of 3,450
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\BthA2dp\Parameters]
"BluetoothAacEnable"=dword:00000000
Prefer aptX over AAC.
How do you set this? I am on Windows 11 Home 22H2, but I do not have [Parameters] in my Registry
Oct 12, 2022 at 5:29 PM Post #522 of 3,450
I just changed laptops so I have to ask: Is there a MacOS version of "Dongle Assistant", or is it Windows only?
I have the older K8 version of the dongle, and of course it cannot connect to any of my TWS devices without the app. So, I guess if there isn't any MacOS version available, the dongle is useless for now.
The dongle assistant is not available for Mac.
Create a virtual PC with VMware Fusion Player. It’s free for non-commercial use.
Oct 17, 2022 at 5:28 AM Post #524 of 3,450
Oct 17, 2022 at 6:20 AM Post #525 of 3,450
Hi All, I newbie I'm using HaiSenKeJi (KB8) with lighting to camera adaptor connect my Pi7
I would like to share KB8 1.8 FW
https://drive.google.com/file/d/1GnBF_m-eZstH6EzYghVOn2ioEDdaAagf/view?usp=sharing
Recommend stetting
Dont check " Enable Microphone"
Audio Mode " Low Latency " the " High Quality" will have some click sound when playback in my environment
Can you confirm this is really for the KB8P? The KB8 cannot be changed with the Dongle Assistant.
My KB8P is currently on fw v1.5.
