KB8 V1.8, KB8P V1.5 New Firmware and Dongle Tool V1.6 Update
New firmware features:
1. To solve the situation where some systems or game consoles can't open the microphone, we have added the ability to force open Bluetooth headsets and microphones to make it more user-friendly and easier to play.
2. You can choose to force the microphone on only with adapter support V1.6 version. This option was not available in previous versions.
3. Fix some known bugs.
Upgrade Instructions:
1. Genuine WINDWODS upgrade is recommended. We recommend using a laptop.
2. Please disable automatic switching of Bluetooth audio function before upgrading.
3. You need to download the firmware for the other model.
Firmware contains two pieces of firmware.
files and instructions
Upgrade to our brand Bluetooth V1.1 or higher
4. If the upgrade is successful, a prompt is displayed. Upgrade Succeeded!
Download:
https://drive.google.com/drive/mobile/folders/1--_nCs4z_d-WrjytT2k6779VhcDo9q5Y
Checking this will force the microphone to be enabled.
