Never again am I backing a product by Hidizs
Pathetic is an understatement regarding their support for this device
I was trying to be a little bit more mellow, but I totally agree with you!Never again am I backing a product by Hidizs
They just re-released a new batch of the device on Aliexpress. I don't think they will abandon it already. And I don't wanna repeat myself...but I do not have any problems reading perfectly DSD format and my friends either. Is it possible that you have a problem on the hardware side and not everyone is affected by it? Like the wobbling knob.
Thank you for the reply. I just downloaded half of the files on that page. And I listened twice the one you mentioned. Just to make sure this is the name. ( And to make sure everyone knows: the AP80 can only support DSD 64/128):Okay, here is a free DSD file you can download to your AP80 and test. On my AP80 this sounds like an unlistenable mess of gurgling hiss and noise. It's the first track: Hoff: Innocence by Hoff Ensemble. It's downloadable in a variety of formats. You can compare it to one of the non-DSD formats of the same track, which sound completely hiss-free on my DAP. I would love to find out if this sounds OK on your device, as that would mean the DSD problem is limited to certain devices, which I highly doubt...
http://www.2l.no/hires/
Hoff: Innocence
Hoff Ensemble
Stereo DSD 128
5.6448Mbit/s
423MB
My device plays the file perfectly. Are you certain it is the 128 and not the 256 you are playing?
2 set of earphones and 2 set of headphones. No noise, no hiss, etc. I will download the 64 and the 256 just to compare with the 128.I just tried the DSD64 one. And compared it to the CD 16bit/44kHz one, which is perfectly clear and silent.
Have you tried listening with headphones as this will show up the noise better?
I just listened to the 64, it was perfect too. And obviously the 256 gave me an error. I thought it would start and gave me all kind of artifact, but no.2 set of earphones and 2 set of headphones. No noise, no hiss, etc. I will download the 64 and the 256 just to compare with the 128.
Maybe try resetting the AP80 maybe you touched something you should not.
1.0.1 BetaThanks for testing this. I will try a reset, but this was one of the first things I noticed with my AP80. Which firmware are you on?
1.0.1 Beta
I was wired all the time btw. No bluetooth.
I am really sorry to hear that. I bought mine on Ali and they where really helpful. I would try contacting them if you bought yours there too.Just did a system reset and the DSD noise persists (1.0.1 Beta)
Good luck.
