Android phones and USB DACs
post-8959039
Post #1,036 of 9,413
gikigill
My iBasso PB2 amp and DB2 DAC combo FINALLY WORKS with the USB audio recorder!!
HALLELUJAH!!
post-8959123
Post #1,037 of 9,413
CZ Eddie
Does anyone know if you can take the output of a DAC and connect it to the USB input on a car stereo?
Right now I'm using my UCA 202 DAC output to my Car Stereo using the AUX input.  But the AUX is on the front of my car stereo.  And there is a USB on the back.  So it would be a cleaner looking install if I could connect the DAC to the rear USB input instead of the front AUX.
post-8959237
Post #1,038 of 9,413
JCJiffy
Oh wow. Audioquest DragonFly works with USB Audio Recorder Pro connected via OTG USB to my Galaxy Note II, BUT, I cannot control volume. Anyone have ideas for controlling volume other than outputting from the DragonFly to an amp?
Reactions: DanBa
post-8959688
Post #1,039 of 9,413
DanBa
As far as I understand, you should require the developers of USB Audio Recorder PRO to implement the USB Human Interface Device volume control ("Info", "Email the developers").
About USB HID:
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/345#post_8721040
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/390#post_8741055
post-8959817
Post #1,040 of 9,413
i_djoel2000
hi guys.. i found out rather interesting thread over at xda-developer
will this kernel enable my xperia neo to act as transport to usb dac? it has usb OTG feature: http://forum.xda-developers.com/showthread.php?t=1566871
i would like to try this myself, but i don't have usb dac at the moment
post-8960012
Post #1,041 of 9,413
henrylar
"music stored on Galaxy S3 > USB Audio Recorder PRO player > digital USB audio out >> "USB OTG" cable >> FiiO E17 >> headphones"
Hi Danba. Which music formats have you got working with the recorder? It would be very exciting to be able to use it as the music player with formats up to 96/24. I have tried the USB Audio Recorder Pro with flac on Nexus 7/ FIIO e17. The program seems to recognize the DAC - but I cannot get it to play flac files  from that programme, but the N7 works with the 4.2.1 ROM and Faux kernel, however only when attached before you turn on the N7.
post-8960245
Post #1,042 of 9,413
CZ Eddie
Not necessarily.  For instance, CyanogenMOD has USB-OTG but does not yet support DAC's.
post-8960441
Post #1,043 of 9,413
chrdxn
I'm trying to get a new Fiio E07K to work with my Galaxy S3, but can't get it to work using via USB/OTG cable except for one brief time yesterday where Spotify was playing just fine for about a half hour, but when I tried later that night, it was no good. Here's what I can tell you:
- Stock Galaxy S3 on AT&T with Jelly Bean
- The E07K is recognized by the phone it can pass digital audio. I successfully tested this via USBAudioTester app (GS3's mic input passed through dac to headphones via OTG).
- Music Player: It looks like it is trying to play, but the track time counts up way too quickly.
- Spotify: Not sure what I did, but I was able to get Spotify to play via OTG for about 1/2 hour yesterday. All other attempts before and after failed. No sound plays.
- Pandora: No sound, just immediately keeps skipping tracks over and over
I should also mention that two others reported getting the E07K to work with a GS3 on a different thread here. What am I missing? Obviously it CAN pass the audio, but something is not right. As a last resort, I tried it immediately after a factory restore... no luck, so it doesn't appear to be a conflicting setting.
post-8960553
Post #1,044 of 9,413
henrylar
I got it to work - did not recognize the button to choose music format.. It plays 16 bit music fine, but it distorts 96/24 files, even if it triggers the FIIO to choose that. Hopefully the developers just need some time to solve that.
What a wonderful development!
post-8960625
Post #1,045 of 9,413
turokrocks
Give it some time, and you will be amazed.
I got high hopes for Davy.
post-8960743
Post #1,046 of 9,413
DanBa
I get 16/44.1 and 24/44.1 playback.
But I can’t get correct playback with 24/96 files through 24/96-capable ODAC or FiiO E17.
The 24/44.1 Old Balloons from Boots Met My Face is freely downloaded from the following site:
http://christmas.linn.co.uk/
post-8960780
Post #1,047 of 9,413
DanBa
Are you sure of your USB OTG cable?
You could test it with a USB mouse.
post-8960806
Post #1,048 of 9,413
DanBa
As CZ Eddie, I don’t think this kernel supports USB audio.
"Added support USB-OTG [i.e. USB host mode] (Keyboard + Mouse + USB-Storage) [Only Full Version]":
. "Keyboard + Mouse" => it supports USB class for human interface devices (for example, mice and keyboards).
http://developer.android.com/reference/android/hardware/usb/UsbConstants.html#USB_CLASS_HID
." USB-Storage" => it supports USB class for mass storage devices.
http://developer.android.com/reference/android/hardware/usb/UsbConstants.html#USB_CLASS_MASS_STORAGE
. Not a word about USB class for audio devices.
http://developer.android.com/reference/android/hardware/usb/UsbConstants.html#USB_CLASS_AUDIO
If you have a USB DAC, you may test your Xperia using USB Audio Recorder PRO.
post-8960943
Post #1,049 of 9,413
chrdxn
Yes, the OTG cable works, and the GS3 CAN recognize the E07K. I know this because I ran an app called USBAudioTester which identified it as Fiio USB DAC-E07K. When I select that as my device, I can run a test called "int Mic to ext Speaker". This test takes any sounds picked up by the Galaxy S3 mic and sends them out via USB. When I snap my fingers or knock on the desk, I hear it a split second later through the headphones. So the device can be recognized and process audio via OTG. It's just that any music player I throw at it does not work. It does work on my iPad via Camera Connection kit, and it also works on my computer via USB.
post-8961166
Post #1,050 of 9,413
i_djoel2000
bummer..
thanks for your reply mate
