I am wanting to start listening to Tidal (lossless) using my android phone (S21) connected to my DAC (Schiit Modi Multibit) via USB. Making the connection is not an issue (I'm assuming I will need to use a powered USB hub to avoid the potential for a "too much power-draw" error). The issue I am wondering about is essentially what this thread is all about: what sample rate am I going to end up getting? Unfortunately my DAC does not have a display to indicate what the current sample rate is. I am assuming, based on what I have read so far on the topic, that I will be forced into a native Android output of 48 kHz / 16-bit, which in itself wouldn't be an issue for me (I consider either 44.1 or 48 kHz at 16-bit to be quite sufficient), but the issue is that I will be playing Tidal lossless which is at 44.1 kHz (I will have all my tracks pre-downloaded so I don't want to use the "master quality" setting, which is only available for certain tracks anyway). So therein lies the issue: having the Android system resample from 44.1 to 48 kHz. This is certainly not ideal and a situation which I would otherwise avoid, but if I want to use this setup, I don't see any way around this, particularly because I don't want to root my phone.
So all of that was a long-winded way of getting to my actual question: how "bad" is it to resample from 44.1 to 48 kHz? I'm guessing I will have every 45th-or-so sample essentially repeated twice-in-a-row in order to "up-sample" to 48 kHz; would this result in any perceived degradation in sound reproduction? Any insight into this would be greatly appreciated (or a tip as to how I can force my phone to output in 44.1 kHz without having to root it).
