Bubblejuice
- Nov 28, 2016
Does anyone know how the Essential phone USB C DAC dongle compares to the Quad Dac in the LG V20 and LG G6+ (Or International version of the G6)?
Which device?Hey, anyone have any idea how to connect a device with built in power thru OTG without getting power from the host device(being charged) or any DIY OTG cable that does this?
Cheers.
My friend will be using it with Zishan.Which device?
I've tried some cables and the only one that did that to me was the micro usb to micro usb otg cable that came with my SMSL M3. And I really don't know why. All the other cables fell into two categories: 1) The host does not recognize the device due to a lack of power or 2) the host start to charge the device and drain really fastHey, anyone have any idea how to connect a device with built in power thru OTG without getting power from the host device(being charged) or any DIY OTG cable that does this?
Cheers.
Can you recommend a good OTG Type-C cable for my DragonFly Red? (OnePlus 5)
Try the new FiiO CL06 OTG cable, it can be found on AliExpress.
I need something like this (with female connector) to plug in DF.
I suggest to look on amazon, they will likely have something like this.
Should do the job nicely, Anker makes nice cables.At the end I've taken one from Anker.
I received the above mentioned iFi pieces today (one micro USB the other USB C) and they are quite nicely made, easily bettering the build quality of the $1.99 more expensive Audioquest DragonTail. Not sure why they turned the orientation of the input 90° relative to the output.
@iFi audio : does the above appear to have been properly manufactured? none of the product images depict the connectors that way including the one on the box front, and at least one other user who received the same 2 cables yesterday said his do not have the connectors at a right-angle with each other.
