Does anyone know how the Essential phone USB C DAC dongle compares to the Quad Dac in the LG V20 and LG G6+ (Or International version of the G6)?
I am also looking at getting the essential phone, Any details?
Should do the job nicely, Anker makes nice cables.
I received the above mentioned iFi pieces today (one micro USB the other USB C) and they are quite nicely made, easily bettering the build quality of the $1.99 more expensive Audioquest DragonTail. Not sure why they turned the orientation of the input 90° relative to the output.
@iFi audio : Does the above appear to have been properly manufactured? none of the product images depict the connectors that way including the one on the box front, and at least one other user who received the same 2 cables yesterday said his do not have the connectors at a right-angle with each other.
Really it has a better build than Dragontail? How about audio quality response?
Do suggest to use a powered Hub instead.
Sometimes phones does not deliver enough power to usb DACs like my LG V20.
I need to have external power to use my Geek Out 1000. Instead my old Samsung Note 3 is all plug-and-play.
Can't see the picture but if you mean the ZMI Usb Pd Backup Battery & Hub:
https://www.amazon.com/ZMI-Pixelboo...B072BD98CM?ref_=w_bl_hsx_s_wi_web_16952605011
Haven't tested it, but based on the description yes it will definitely will fill the bill.
