thatACDCguy
- Mar 16, 2017
Hi, I'm looking at upgrading to an HTC 10 and was wondering if the Vamp Verza is compatible. If not, what are good DAC alternatives?
Why wouldn't it be?
Verza compatibility is a bit hit or miss. I own one and while it works perfectly with a stock Galaxy S3, it doesn't work with a stock Galaxy S4. I've had luck installing custom ROMs on unsupported devices, like the original Galaxy Note, and using USB Audio Player Pro, but most ROMs break the native USB audio implementation.
Honestly, if i didn't have a Galaxy S3 with the docking Metallo case to go with my Verza I would never use it. It's been 4 years since the Verza came out and there are much better options available today.
The Dragonfly Red series looks pretty good specs-wise, but it looks like the manufactures only provided micro-USB support, not USB C.
Hi, can anyone confirm that small dac / amp works on Lenovo with android 5.0.1?
I have the FiiO e17k and although it recognizes it by OTG, it does not work on 24/96.
With the Nexus 6 in 7.0 I have no problem
I do not use third party apps ... it's to listen google play music in streaming
Thanks
I don't think that matters.
Nexus devices will usually default to 16/44.1 unless you use a third party app.
What rate are you getting on the Nexus 6?
