m-i-c-k-e-y
Here it is: http://www.head-fi.org/t/704065/usb-audio-recorder-pro-uapp-24-and-32-bit-playback-ubiquitous-usb-audio-support-for-android/1185#post_13323036
Thanks!
For the OTG cable for your S5 and RSA Raptor. I could only find are these:
https://www.amazon.com/StarTech-com-Mobile-Device-Adapter-UMUSBOTG8IN/dp/B018M8YNDG/ref=pd_sim_147_3?_encoding=UTF8&pd_rd_i=B018M8YNDG&pd_rd_r=A6CVMR1DQ1VPXF3Z33NQ&pd_rd_w=3iVZh&pd_rd_wg=pYfd0&psc=1&refRID=A6CVMR1DQ1VPXF3Z33NQ
https://www.amazon.com/Lindy-0-5m-USB-OTG-Cable/dp/B002VUZXBI/ref=sr_1_1?ie=UTF8&qid=1489045069&sr=8-1&keywords=lindy+31805
if you want shorter you may want to go to a short adapter + otg cable route.
Shortest possible adapter.
https://www.aliexpress.com/snapshot/0.html?orderId=81287757756279&productId=32647486962
Has anyone connected an Android to a Schiit Modi? I thought a standard micro USB to USB B cable would work, but Schiit's website mentions that a powered USB hub is needed.
Any suggestions?
@shuto77- The Modi can work with Android [notwithstanding the fact that not every DAC works with every Android device]. You will need a USB OTG cable that ends with a standard 'female' USB socket, you then plug an externally powered USB into that and the Modi into the hub. The Modi draws too much power so needs to be powered.
I had it working with a Samsung Galaxy S5 and Moto G (3rd Gen).
shuto77 - the standard Modi is USB only, the Modi Uber has AC (sounds like you have that one), I only tried with standard USB version so Uber may work without a powered hub. Won't hurt to give it a go without the hub and see what happens. Don't forget to get high-res you'll need UAPP or something that will send a signal direct to the DAC.
