greenpsycho
- Aug 22, 2015
Maybe stupid question, but how would one go about checking if it resamples? I know some dac's have indicator lights to show what bitrate, but I just have my modi2
Popping back into this thread to see if there is progress with Lollipop outputting bit perfect. Did not see much progress based on a quick skim and read.
I also found this thread on official Sony site: http://talk.sonymobile.com/t5/Music/Why-did-you-remove-HD-Audio-via-MINI-USB-out-in-Lollipop-update/td-p/976707
It is official: the Lollipop (if the sound goes through the Android framework) upsamples the output from players always to the highest sampling rate that the DAC supports. For Sony Xperia devices at least.
http://talk.sonymobile.com/t5/Music/Why-did-you-remove-HD-Audio-via-MINI-USB-out-in-Lollipop-update/m-p/988252#M4299
What a dumb decision on Google's part, and this time Sony is not promising their own implementation like they did in KitKat.
If this is the case, the work-around is to use a DAC that only supports at most the same sampling rate that your music is.... Off the top of my head I cannot think of any that would help us redbook CD guys who want to stream music from Tidal in addition to or instead using UAPP or Hiby or Onkyo...
If anyone has seen any evidence of bit perfect playback on Lollipop, would be great if they let us know. Maybe there are tricks to this requiring rooting which I am considering seriously doing for the first time.
It would be really pity if I would need to move to iDevices because of this, would prefer to avoid a closed ecosystem. I was thinking of buying a Sony Xperia Z3 Compact Tablet to use as source around at home, but I hear they are now shipping with Lollipop...
Not too sure what that means. I also did not run it attached to the dac (don't know if that matters or not either, cause frankly I don't understand what this test does)
A new version of Hiby is available, 2.0.4.
NEW FUNCTIONS
4.Add sorting by album under artist
NEW FUNCTIONS
1.Remember the file catalog browsed last time
2.Support folder skip
3.Display the album cover on LAN
5.Support deletion of the whole album/artist
6.Display output information by keeping press the cover on play interface
7.Bugs fixes
Nice. I would like to see landscape mode added though, as I am toying with the idea of using it on a tablet.
NEW FUNCTIONS
7.Bugs fixes
Just updated and it crashes when rescanning my music folder. I've uninstalled and tried a clean install however it gets to 242 songs and crashes each time. Dammit!
Mine scans everything, 719 songs in all. Perhaps try a restart?
Nope still no go. Restarted and tried another fresh install and still crashing. I tried scanning all folders instead of just my music on my SD card but it didn't help. You guys using SD cards or all internal?
