jared basshead
- Jun 28, 2012
Yes rooted and expert mode.
But what it has to do with expert mode?
It's a passive device, if its impedance doesn't load the DAC output then you are good to go. Unfortunately they don't spec the resistance of the potentiometer or the taper. You need an audio taper stereo potentiometer. Probably around 1 K Ohm would work well.
Thank you for helping with the suggestions.
I did a small amount of research on potentiometers. It looks like the majority of the higher end ones use a much higher ohm rating than 1k?
Here are the specs of my current equipment. Will this help confirm your suggestion of 1k ohm potentiometer?
Behringer UCA202 USB DAC:
Output impedance - 400 ohms
to
Alpine PXA-H800 car audio processor:
Input Impedance: 10k ohms or higher
The volume control would go between these two devices.
Galaxy Note 1 |
How about using with tried and tested app...
I want to get a sound output straight from the kernel, not from the app as I want sound processed also by Viper4Android.
With my previous phone (S3, Boeffla kernel) it worked flawlessly.
Is anyone else experiencing tracks randomly skipping by itself when using UAPP? It happens occasionally and occurs with both the screen on and off.
And you know players like Neutron they use the Android sound layer. All files (be it 24/192 PCM or DSD128) are converted to 16/48?
With HibyMusic or UAPP, they communicate directly to your DAC (use their proprietary usb drivers) therefore able to play files what your DAC can support.
Yes I know that. Still prefer the sound that's processed through Viper4Android and Android sound layer.
With my last DAC Musical Fidelity V-DAC I could not hear a difference between 16/48 and 24/96. OK, now my sound system is much better but that's another story![]()
