JediSpam
- Mar 17, 2008
does anyone know about the audioengine d1 working with an android device?
I just received my HiFimeDIY Sabre Android DAC. I ordered it on 8/15 and it arrived here in San Diego in today's mail. 15 days.
I am using with a Sprint Galaxy S4 (quad version).
It is really plug-and-play. I just plugged it into the micro-USB connector and my headphones in and all the audio from the phone is routed out to the headphone jack of the HiFimeDIY!
I have only had a chance to listen for a few minutes, but doing a quick comparison between the built-in headphone output and the HiFimeDIY DAC on my modded Koss Porta-Pros, to me, there is a night and day difference!
The Sabre DAC just sounds so much better all the way around. The highs are much more detailed and clean. The lows are WAY better!
I will listen further and try with some better headphones. I will try my Heir 8.A's and also my Stax 407 rig later.
Nice. How loud do your headphones get compared to the built-in headphone jack?
The Koss PortaPro's are not very sensitive (60 Ohms), so on both the built-in and the HiFimeDIY are at full volume for a relatively OK listening level. But it also depends on the files being played.
With my Heir 8.A CIEMs, the built-in audio is about twice as loud at the HiFimeDIY. I am surprised that the HiFimeDIY isn't louder. My CIEM's are pretty sensitive. Still, I can get decent listening levels but I have to set the output to 100%.
I have to qualify that I am using "processed" audio files that are recorded at a lower level. So with commercial audio files off iTunes, I am guessing I wouldn't need things turned up so loud.
The DAC is supposed to be used with an amp. It is not intended to be used alone, but it works in a pinch with sensitive headphones.
Output levels:
Open 2.2Vrms
4.7Kohm 2.1Vrms
1.8Kohm 1.9Vrms
510ohm 1.5Vrms
330ohm 1.3Vrms
30ohm 1Vrms
If the SII allows USB OTG without any issues and provides power, it should possibly work (with android 4.2.2+). The key lies in having android 4.2 or higher.
My Nexus 4 doesn't work directly, because it cannot provide power to it. I'm waiting on an OTG y-cable which I believe should allow it to work just like the Nexus 7 (with a USB OTG kernel).
I will be getting a number of HiFiMeDIY DACs and I will be testing them with the S2. My S2, a standard i9100 as far as I can tell, works well with OTG on kernel 4.1.2.
Success!
