StanD
- Oct 2, 2013
This was posted a couple days ago.
http://www.extreamsd.com/USBAudioRecorderPRO/
If I was to go with a non Native USB Audio hookup I'd prefer Onkyo HD player software.
Hi! I am having some troubles with tuning the sound with Neutron. I just bought Samsung Galaxy s5 after using S2 for a long time. I am listening to lots of dark ambient, where low tunes and bass are frequent. To me Neutron keeps lacking some detail or richness, as if S2 (default music player) has all sounds slightly more tight and defined.
Thus I am not sure if this is related to the phone itself and that S2 simply has better sound. I am not familiar with the functions of any of the systems within Neutron. Maybe someone can point me in a direction of what I could try "tuning" within this app?
Tried using this player again yesterday after about a year, still can't use it.
Even with superior sound quality than other players, I can't get over how useless the UI is lol, it's just too un-intuitive and not very user friendly. It even gets laggy while scrolling on my note 4!
What does the default player on on the S5 sound like?
Same, can't tell any difference. Tried both with Fiio and without, with Beyerdynamic 770 over the ears. Could it just be that S2's sound quality was better?
I believe there are different versions of those headphones. Which is it and what are their impedance?
Ah yes: Beyerdynamic DT 770 PRO, 80 ohm
I thought that they might be 600 Ohms and that could be a possible cause as it would require a voltage swing that your phone couldn't achieve.
I understand
I did some digging and came over one of your earlier posts that advised to experiment with the default and a new preset. That helped alot, now at least the sound seems closer to what I am looking for. I still am very new to this, so if you have any other tips for that kind of music (atmospheric, non-rhythmic, lots of low tones and frequences, as well as bass, but at the same time very detailed) I would really appreciate it. If you have time, here is a short example: https://www.youtube.com/watch?v=Gq9aEgB5nlE
Cheers!
Can I use Neutron on two devices if I buy it in the play store or do I need to purchase Neutron for each device?
