Want channel separation ?
Wooaudio W234 Headphone amps Mono blocs !
Only 60 lb... per channel.
![](https://www.head-fi.org/attachments/933724/)
![wink.gif](http://files.head-fi.org/images/smilies/wink.gif)
Want channel separation ?Wooaudio W234 Headphone amps Mono blocs !![]()
Only 30 lb... per channnel.
The spec say 60 lb per channel and also 7500 USD per channel too.![]()
nothing will be damaged due to the batttery pack protection circuit, the first time i did this for more than half an hour!
Good !
GermanGuy, Question: according to your spreadsheet, the PHILCO have a much higher current drain than some other much more frugal tubes !
So... don't you have a shorter battery life with this PHILCO 1S4 + RTF 97 combo ?
Done.... I ordered a XLR plug for my Mod. I tried to choose one as short as possible...![]()
I hope that it will fit inside the short TU-05's case (in place of the charging plug)
- For the XLR cabling I will use the same cooper cable that has been used for re-wiring my TH-900 balanced. And since the 2 (right & left) ground of the transformer output will not be connected together anymore, may be I will experience a better channel separation ? What do you think GG ?
Which type / order number / manufacturer ?
After ordering how long does it take for the amp to arrive? A month, 2 months?
I ordered 2 different type... in case :
http://www.audiophonics.fr/neutrik-nc4fdl1-embase-xlr-femelle-poles-p-5753.html
http://www.audiophonics.fr/monacor-nc505j-embase-xlr-plaquee-femelle-p-7821.html
Why not the black aluminium neutriks ?
