GermanGuy
- Apr 9, 2013
I know you've already bought it, but there are alternatives which offer 192KHz capability (e.g. iBasso D7)...
There is an alternative (as posted before) - the Meridian Explorer, capable of 24Bit, 192 KHz, - BUT - needs a driver for example for Windows, so not universal, i got the HRT microstreamer for 163 Euros, The Meridian Explorer is 299 Euros, much larger, three time the size / volume.......
And in several reviews the HRT was the better sounding device, the description of the sonic signature exactly fits my wishes, due to shape and connectors it can be provided as Add-On and can also be removed, housing is strictly rectangular, out of aluminium and two screws on the back so can be mounted by just using two slightly longer screws and .. it is really small.
so much more requirements needed to be fullfilled than just sample rate for an easy integration.
And as the colorfly loves WAV but hates FLAC i have decided not to use 192Khz.
Just to remember this device will be integrated into my TU-05 as dac section !
