Hello. I meed your advice to built the best portable solution for My IPAD / iPhone. I hope someone can help and I apology in advance for the "too many" questions here.
I intend to purchase a CLASS/ALO Rx MK3 combo plus the appropriate Headphones. But I also look at the SR71b as an alternative to the ALO rxMk3 ! And even at the ALO "Continental" !
As for headphone, I am looking at the LCD-2 (or 3) as main headphone, but I also will need a closed type headphone for use at the office for exemple
So... here are my questions :
- Is there any advantage to use the LCD-2 on the ballanced output of the Mk3 when the Mk3 is driven by the CLASS through it's single ended imput ? (same question for the SR71b:
- Is there a "ballanced Class" coming soon ? (stupid question, I know, but some rumors may have leaked somewhere...)
- I heard about a "single ended imput - to - ballanced output" circuit in the Sr71b ? It true ? Does the ALO Rx Mk3 has a similar circuit ?
- What do I need to order if I want the LCD-2 with a very good "upgraded" cable and being able to use it ballanced (on the Mk3/SR71b) BUT ALSO single ended (on a regular amp) ? It is possible to have an ALO cable + an adapter instead of 2 cables (ballanced & Single ended). Which part N° I need to order ?
- I also need to have a "close type" headphone to use when sould leakeage is not possible (office....). Which close type do you recommand ? Will it pair well with the Rx Mk3 ? ALO is offering the Edition8 with an upgraded cable, has someone tested this headphone with a portable set-up ?
- Is the LCD-3 really better than the LCD-2 for such a portable set-up ? does it justify the added costs ? isn't it "too analytical" on such a portable set-up ? Wich one you recommend with the RxMk3 : LCD-2, LCD-3 or GS1000 ?
- I am still very tempted to order also a Continental to have access to this "tune sound". Will it also pair well with the LCD-2/3 and Edition 8 ? Will the sound be very different ?
- I already have some Westone ES3x custom IEM. I read few times that the Rx Mk3 may be too powerfull for those IEM and therefore need to be used at very low volume setting (3 oclock, even with "low gain") and that at this low volume setting, there is some channel un-ballance and some noise. Is the Mk3 really appropriate with Custom IEM ? Isn't the SR71b offering "blacker background noise" at this low volume setting ? or the "continental" may be ?
- I know that with the iPAD I can "extract" the digital signal using the CCK, but... I read somewhere
"IT MAKES MORE SENSE to use a digital dock, like CLASS to get the digital signal out of the iPad with less jitter than the CCK". --> What do you think about this supposed added Jitter coming from the CCK compared to a SOLO ? (I know that with a CCK, I will need an external DAC, so this is still an additional box (iBASSO ballanced DAC ? ) or...I forget the SR71b/ALO Rx and find a very good DAC/AMP ?
Thanks in advance for any answer and VERY sorry for all those too many questions
Bertrand MICHELS
