I am using Shunyata venom 3 power cable.
are you using the toxic cable's venom cable?
I also heard some hissing sound when using my sony iem ex1000. Hissing sound is irritating and make the silent passage in classical sound like internet radio quaility. I manage to completely remove the hissing sound by using an in line volume controller. Now the back ground is as black as my RSA hornet... dead quiet.. so dead I thought its dead .
Can be bought at amazon for $17.25 and will not degrade the sound.
Here is what I did:
1) Plug the shure controller at full volume in rx 3
2) Lower shure in line volume controller knob until hissing sound completely gone
3) Turn up Rx 3 volume slowly until comfortable level... you are all set now.. hissing sound completely gone.
4) I notice I have a lot of play on the rx volume now and my Sony IEM uses the same amount of volume as my HD650 on the RX 3.
5) No need to send back to Ken as he is not able to reduce the hiss as mention in earlier thread. use this gem and gain at least 5% of happiness.
my rxmk3b balanced out +alo balanced to
3.5 protector cable.
soprano has noise!!
email to alo
alo reply to email …
excuse me, so what can i do to balance ?
Ricky,
This is not a recommended set-up. This could even potentially damage your amp. The balanced to mini cable is mixing the grounds from the balanced output of the RxMK3. We recommend either a balanced cable or a single ended cable for use with the MK3. Sonically these are very equivalent, as we worked hard to eliminate the difference between the two outputs. But please refrain from using this cable further with the amp because of the potential harm it may cause. If you have any other questions I'd be happy to help. Thanks, -Caleb
soprano has noise!!
email to alo
Ricky,
