olblueyez
Banned
- Jun 16, 2008
Quite right, or just get the ATH-AD900, or the Grado SR-225, or the Denon AH2000, or one of the Sony models and plug them straight into your sound card and enjoy great sounds and gaming with NO extera expeditures.
Originally Posted by parhelictriangle /img/forum/go_quote.gif Please don't let anyone convince you that you need to spend on cables at this point in your journey. And don't listen to the crap about upgrading to a dedicated CD player. You're using your computer as a source, and that's perfectly fine. Double amping, like you're doing now, isn't going to get you great results (although glad to hear you solved your problem). You have nice headphones if you like the sound signature. What you need is a good external USB DAC and a headphone amp. The DAC will bypass your soundcard and deliver a nice, clean signal to the amp at the right line level. Maybe look around at amp/DAC combos. Headroom has a few, and there are plenty more out there. By most accounts, the k70X series is pretty power hungry, so it might be best to avoid the really cheap portable solutions. Although feel free to try-- I have no experience with your headphones, but the negative effects of not spending 10 grand on your setup are greatly exaggerated around these parts. I honestly can't believe how many people are quick to suggest dumping thousands into cables, interconnects and an expensive CD player for someone relatively inexperienced. It's frigging disgusting. Get a USB (or firewire, if you have it) DAC and an amp. You don't have to break the bank. If you want to tweak things later, nobody will stop you (and most, apparently, will encourage you), but don't drown in snake oil and relatively inconsequential tweaks before you even get started. |
