fishski13
Member of the Trade: SolderWorksAudio
- Nov 2, 2004
i owned the K701 for 2.5 yrs.
the 600 ohm are reportedly smoother in the treble. i actually thought they were a bit a bit too muted and rolled-off until about 100 hrs. go figure.
edit: no harshness with the K701/Bijou, but ultimately lacking in musical drive and grip.
Originally Posted by ksu06 /img/forum/go_quote.gif I respectfully disagree about the comment regarding the treble, at least for the 250 ohm version; I tried a DT990 250 ohm and I own a K701, both used on my set up and I found the DT990 treble to be much more forward and at the same time more harsh and fatiguing. The K701 has great treble extension but does it much more smoothly, and as a previous post suggests, more like you are further away/above the concert ... I would hazard a guess that your K701 was not fully burned in as untame treble is certainly a sign of that (just a guess of course) and as it has been well documented on Head-Fi, the K701 needs hundreds upon hundreds of hours to reach full burn in |
